Idling
Old Feb 13, 2017 | 09:59 PM
AbeG37vq's Avatar
AbeG37vq
Idling
Hello. I've noticed from time to time that my car vibrates just a bit when im at a stop light. THis doesn't happen all the time. Sometimes i've noticed my RPMs at around 550-600 at a stop light. other times i've noticed my RPMs at 500 and I can feel a slight vibration. The CEL does not come on when this happens. Is this normal? Thanks.
Old Feb 14, 2017 | 01:20 AM
Jonesmeister11's Avatar
Jonesmeister11
My guess, dirty throttle bodies.
Old Feb 15, 2017 | 08:30 PM
AbeG37vq's Avatar
AbeG37vq
Throttle Bodies
How does one properly clean the throttle bodies on a G37?
Old Feb 15, 2017 | 08:51 PM
hurleyguys's Avatar
hurleyguys
Old Feb 15, 2017 | 09:07 PM
DavidTB's Avatar
DavidTB
I use to have that problem with a fuel injected Honda Accord in the winter. Id add a bottle of injector cleaner in the start of winter and it would clear up the problem till the next winter.
Old Feb 16, 2017 | 02:32 AM
AbeG37vq's Avatar
AbeG37vq
Update - I cleaned the throttle bodies about 2 hours ago. I'd say it took me about 1 hour since this was my first time doing this on the G. Thanks @hurleyguys for posting the video. This really helped a lot. I made sure I didn't touch the butterfly plates and blasted them with throttle cleaner on both sides of the TB and wiped around the plate. I did not disconnect the battery or the TBs. Cleaned the gasket that goes between the TB and the plenum. Also, I covered the MAF sensors to protect them from dust/TB cleaner/grime. After putting everything back together, I did notice a difference in idling, which was smoother. Throttle response did improved a bit as well. I really couldn't do fast runs because of traffic so I'll give this another shot on my way to work tomorrow. So far everything seems good. No SES light.
Old Feb 16, 2017 | 07:08 PM
saywat?'s Avatar
saywat?
i prefer to just remove the tb completely and sit down on a table and thoroughly clean it rather than do it the way the guy in the video did
