Tanabe exhaust tips not sitting flush
I just recently installed the axle back exhaust and the tips are not sitting flush out back...you can see the right side is much higher than the left. i'm super OCD about it and what them to sit flush together. i've been back under the car to check and ensure to tighten everything up and its all fine. dont know what else to do to fix it, any ideas?
Check your left OEM hanger with the metal and rubber portion, it looks like its either bent a bit or the rubber is loose and letting it sag a bit.
Mine did this a just a hair only about 1/4 inch but like you I have OCD with that stuff too. Adjusted the hanger and voila good to go.
There's nothing wrong with the parts except that they need to be adjusted. Gently bend the hangers up, down, left, or right so as to position the tips where you want them to be.
Brian Londry
20
Apr 17, 2022 11:49 PM
OfficialG
18
Jun 10, 2020 01:40 AM
alexy626
Jun 22, 2016 01:54 AM
