Review TWM Short Throw Shifter (STS) and Z1 Transmission Mount
#61
So, are there any driveline negative consequences with installing a stiffer mount? Are we transferring any of the movement to another driveline piece? I'm thinking long term.
When I threw in a poly motor mount and lightweight flywheel in my maxima, Id find myself revving just to watch the RPMs jump and the racecar vibration.
#62
#63
I joke, but actually my old Maxima's RV mirror started shaking after swapping in poly mounts.
#65
Pretty minor expense compared to the gears I originally planned for 2016. Looking at your sig line, I know you know what I'm talking about.
#66
Kinda freaking out here. I've had the cucha thunk noise with my clutch I started a thread about awhile ago. It got noticeably worse with thus mount. Figured it was the price to pay and though it made me cringe I dealt with it. Today I'm at a light and I hear a full rattle. Like metal on metal rattle. Car deuces fine. Shifts fine. And can't replicate it but it did match the revs ever so slightly for s moment and has since gone away. I love the mod and am hoping it's just the dumb tech not tightening down the cover or something. Will be visiting dealer soon and update.
#67
#68
no it's much more than the standard noise when engaged. I've had this installed for a few weeks now and ever since I did the already present "clunk" sound when disengaging the clutch got worse but I let it go. Today it was rattling at idle so bad I know without a doubt something is wrong. It's gotten progressively worse since Install. Just curious if anyone else has had an issue.
#70
You know, IDK what this clutch noise is that you and Furlow are talking about. Not saying I don't have it, I just suspect if I do, it's not so pronounced that I'm aware of it. It really is a noisy car, and not just because of the exhaust. Looking back, Nico-derm and MaQG37 are also discussing this "cement mixer" noise.
Only thing I can relate this to is when the engine is cold. Car sounds positively horrible, like an old diesel truck. It's downright embarrassing. And somehow it changes when you engage the clutch, which I really don't understand. But that's just when cold. Soon as it warms up, all's right with the world.
Still on the list, tentative now for Spring 2017. Figure to buy the seal kit and the rear-diff bushings at separate points on the calendar from the gear & pinion, and then the actual install, early Springtime. Not a cheap mod. Exactly the kind of expense that's difficult to get past the wife's veto... which is why I went with the mods I did this year.
#72
Yes, absolutely. But it's awkward, and pretty much center to the car. Front ramps alone probably won't be enough, but I'm just making an assumption about that. However, if you're OK putting the whole car up on stands and rolling underneath, you'll be fine. Putting your car up on a lift is obviously better. And paying a trusted mechanic is best, but certainly the lazy and more expensive approach.
micafd3s (05-22-2016)
#73
The shift boot I purchased from Redline Goods hasn't arrived yet, so I held off on installing the STS this weekend. Transmission mount install is still a go for tomorrow. Can't wait!
#75
Which would be a shame because this is an EXCELLENT mod. The car feels more planted while accelerating through turns. The traction control doesn't engage nearly as much as before. Straight line take offs are much more smooth, no wheel/engine hop like before. And the sound (the good sounds) is just amazing.
