Pet peeve: No, you're not faster with VSC off
Old Apr 1, 2016 | 10:50 AM
Victory's Avatar
Victory
So, the Dunning Kruger Effect is a cognitive bias that makes us all think we are Mario Andretti until we slide sideways into a bridge abutment. I was just having this argument with a friend who swore his BMW was way faster with the VSC off. Found this great article explaing why everyone who thinks this is wrong.
http://www.racedepartment.com/thread...-a-lie.103774/
My first car, the car i learned to drive on, was RWD with an open diff and had no TC, no VSC, no ABS. I learned to drive quite well. The road, however, is not the track and even the most skilled drivers can not react faster than a computer. Modern cars and modern technology are wonderful. Leave it turned on. It's not making you slower, just safer
Old Apr 1, 2016 | 11:05 AM
813G37S's Avatar
813G37S
Good read.
Thanks for sharing.
Old Apr 1, 2016 | 02:46 PM
canucklehead's Avatar
canucklehead
my only instrumented proof of VSC slowing things down was at the track in my previous G35. with VSC on, any launch wheelspin - a small amount makes for best launch - triggered the traction control which clamps down on the rear brakes. so i would bog down for a second or so. by that point the run is over. with VSC off this was not a problem and optimal times for my ability, the track, temps and car setup could be had.
in general for the street i agree that VSC should remain on. i switch it off occasionally, but that is not to make the car faster. rather it is to have a bit of 'sensible' fun with rear-steer or if i am out and about in snow (which is rare). try to get moving or get unstuck in the snow with VSC on. it ain't happening with RWD so VSC off is a must.
Old Apr 1, 2016 | 04:23 PM
Victory's Avatar
Victory
I didnt own a 35, but ive heared the vsc in the 37 is better and less obtrusivr. On some older cars ive definitely found it bothersome.
Considering that launch control is just an evolution of the same system, it all comes down to the software.
Old Apr 1, 2016 | 04:30 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Ive owned both a 35 and a couple 37s. The 35 was indeed faster with VDC off as the VDC was hyper-intrusive.. But also less safe VDC off as the 35 was more tail happy than the 37. There was a tradeoff
The 37 is MUCH less intrusive and actually lets you play (safely) a little in corners and making you think you're a great driver- all the while the VDC is really whats in control.
So indeed in the 37 on the street VDC ON is best. At the track its largely up to the driver. But even then VDC doesn't intrude much at all.
Old Apr 1, 2016 | 04:40 PM
Lego_Maniac's Avatar
Lego_Maniac
I don't find the VDC at all intrusive. It even seems to allow a good bit of wheel spin as long as the car is going straight.
I've never turned it off.
Old Apr 1, 2016 | 04:48 PM
jgronline's Avatar
jgronline
I really hate the VDC and found it so annoying that I unplugged my yaw sensor at least 2 years ago to completely disable it. Even with VDC disabled with the button, the stability control can still kick in. It commonly did it when I was making a turn out of my neighborhood where the road isn't level. The combination of a sharp turn and the uneven road would make the VDC light flash and cut power even with the VDC disabled.
With the yaw sensor unplugged, traction control and stability control are both disabled.
Old Apr 1, 2016 | 11:30 PM
SonicVQ's Avatar
SonicVQ
Hanging the tail out is NEVER faster.... but it is FUNNER!!
(Is funner a real word?)
The VDC on the G37 Sport is VERY good. It never kicks in too early or too late.
Old Apr 1, 2016 | 11:36 PM
35Sport's Avatar
35Sport
Sometimes I find that leaving the VDC on leaves me in sketchy potentially dangerous situations. I've had instances where I've had to move quick to avoid a collision and the VDC had cut power leaving me unable to move forward for a split second. I shut it off now entering the highway so I don't experience any power cuts getting up to speed. I have a 6MT so I don't know how that factors in but it's real easy to get the rear tires to slip and I have 275s in the rear.
Old Apr 1, 2016 | 11:44 PM
Lego_Maniac
What kind of tires do you have?
My 6MT with 275/35/19 rears has tons of grip
Old Apr 2, 2016 | 12:07 AM
SonicVQ's Avatar
SonicVQ
VDC only kicks in when there is tire spin.
On dry pavement, I can't spin my all 245 all-season rear tires in any gear under full throttle.
35 Sport: Your rear tires may be too old.
Old Apr 2, 2016 | 12:14 AM
Awesome read man thanks!
Old Apr 2, 2016 | 12:35 AM
35Sport's Avatar
35Sport
Bridgestone RE760 Sports, they're a year old.
Old Apr 2, 2016 | 09:16 AM
That article specifically addresses traction control on a course track. And the video therein is about driving on/off with TC on snow and ice. In both of those situations, conventional wisdom is pretty straight-forward... leave TC on.
However, while I've never taken my G to a course track, I have auto-crossed the car a few times. And although my auto-cross skills are somewhere between awful and embarrassing, it is absolutely a stone-cold fact that you get faster times on an Auto-Cross course with the TC off.
Also, if you want to launch your car out of the hole in the most neck-breaking manner possible, you turn TC off for that too. At least, that's the case with my RWD 6MT with VLSD, some basic suspension mods and Michelin PSS. I can't speak for stock, AWD G's.
In a perfect world where fun is #1, the TC button would be at the top of the shift ****, and respond instantly.
Old Apr 2, 2016 | 10:20 AM
G37sGraphite's Avatar
G37sGraphite
I am going to agree 100% with this...(minus the stupid Rockford files pic)
So in all honesty OP both you AND your friend are correct - it really is dependent on the application.
