Help! Car stuck in ACC mode?
Car warning keeps beeping and keys won't lock or unlock car. Radio doesn't turn on and keys fobs have newer batteries. Can't get my car to turn over. Should I disconnect the battery? I got a new battery in Jan 2015.
It shouldn't have been the headlights, but my car has exhibited strange behavior before the battery has died on me before. I left the headlights on after the car was turned off once, and then next time I went to start the car it completely locked up. Such as nothing in the car responding (door locks, key fob, etc) and the ignition not cranking.
I ended up jumping the car and having weak starts that whole week before being able to replace it. I'm guessing it was the low voltage from a weak battery in my case, maybe it is for you as well.
Known issue for cars 2010-2012 Coupe & 2011-2012 Sedan.
https://www.myg37.com/forums/g37-sed...f-problem.html
I have did not fix it yet.
As the dealer is giving me a hard time already when I reported it.
Even though it has happened a couple of time before I had my remote starter installed they are now saying that they have to test everything and they are thinking that my remote starter may be causing the issue etc..
It's probably a 5 min. software load. And they are making a big deal out of it.
If Nissan found a software glitch and is fixing it by updating software I don't know why the dealer would be even thinking it's remote starter related.
My vin falls within their numbers.
I reported the problem before my warranty expired but they said they never heard of it even though the fix has been available for over 3 years.
I don't want to pay for it myself now. but if they will give me a hard time about, I may just not do it at all. Worst case scenario I can just disconnect the battery when it happens again.
Has anyone else had this problem of the car locking up upon start? If so, did the dealer do a software update per the TSB? My car is out of basic warranty so I assume they would charge around 200 to fix it, I am just debating if it is worth the fix.
Very few cars were affected by this problem. Plus it doesn't happen very often therefore, I don't think there are many people here that had this problem.
The TSB says it's 0.7 hours to fix (apply the software update).
Not sure what Infiniti charges per hours, would think about $140.. so 0.7 hours would be about $100 tops.
BTW, this update shouldn't take any longer than 10 minutes.
pebkac
Mar 7, 2016 10:02 AM
