Headlight Adjustment 2011 Sedan
Just got my new 180 headlights installed and since my car is lowered the projector cutoff is too low. I need to raise up both sides. I've been having trouble finding the adjuster to do this. I believe it is a 8MM white looking bolt that you turn. I started turning it and I could see the lights raising slightly. However, there is a lot of posts in the headlight adjustment thread in the DYI section stating it's a screw that needs to be turned. I don't want to break anything on my new headlights so I'm looking for some guidance. I posted here too as I have time today to fix them, but afterwards it will be difficult. Can't drive at night with my lights pointing at the ground.
I tried to copy the pictures, but check out post 91 in the Headlight Adjustment thread on the DYI page. I bumped it up so it's the first post and posted this same question there last night. Sorry for the duplication, but this is something I need to fix ASAP so I can drive to work tomorrow.
I figured it out. It is the 8MM bolt. You can either turn it with a screwdriver from above or a 8mm wrench which is actually faster than using the screwdriver and not hard to get in there either.
Mik3G37S
73
Nov 23, 2015 02:12 PM
gogetemG
Oct 29, 2015 02:23 AM
tkgrandison
Oct 23, 2015 02:16 PM
