What material is the G37xs oem front bumper made out of?
Old Nov 10, 2015 | 07:31 PM
mjnoles1's Avatar
mjnoles1
I know, odd and dumb question. But, I just got my front end wrapped in a clear bra and of course I parked too close to a deadman strip and scrapped the underside of the front bumper and scrapped off some of the clear bra under the front bumper. Not noticeable, but concerned that it is now not protected.
What material is the oem sport bumper made out of? Concerned about salt, as it is not protected on a few spots where it got scrapped and came off.
Old Nov 10, 2015 | 07:39 PM
ABS plastic, but it will be primed underneath the paint for better bonding.
Old Nov 10, 2015 | 07:41 PM
infamouslkv's Avatar
infamouslkv
I believe it's plastic reinforced with energy absorbing foams & metal. Correct me anyone if I'm wrong.
Old Nov 10, 2015 | 08:04 PM
mjnoles1's Avatar
mjnoles1
Anything I should be concerned about? Since it is now exposed and part of the clear bra got scrapped off the bottom while slowly pulling into a parking space, and snow and salt will soon be on its way.
If I was strictly going with what "blnewt" stated, I would not be concerned but I see the word "metal" in what "infamouslkv" stated which brings me back to a little concerned. Also, if a little of the clear bra got scuffed on the bottom, the rest of it should hold on tight with no issues, correct?
Old Nov 10, 2015 | 08:37 PM
I replaced my bumper a while back (still have the original in the attic). It weighs next to nothing so I doubt there's any added metal, and it's not thick enough to have any foam sandwiched in there.
There is a foam reinforcement behind the bumper cover but it isn't integrated into the cover itself.
Old Nov 12, 2015 | 12:23 AM
EdsNotHere's Avatar
EdsNotHere
Bumper is made out of Urethan plastic not ABS. It's a semi soft plastic vs ABS which is a rigid plastic. No worries about corrosion.
Old Nov 12, 2015 | 12:30 AM
dkmura's Avatar
dkmura
20 Year Member
The bumper cover is actually made from a urethane composite, which will not corrode.
Old Nov 12, 2015 | 03:00 AM
EdsNotHere's Avatar
EdsNotHere
If you want to get down to exactly what it is it's a TPO : Thermoplastic Polyolefin but in the collision industry we commonly call it Urethane. It can be repaired and painted but will not corrode. I would not worry about it. I would trim any loose Mylar (Clear Bra) off to prevent any moisture from working its way under the Mylar film.
Razorr
Jan 3, 2016 10:01 AM
jfisher
Dec 15, 2015 07:15 AM
Nsodano
Nov 8, 2015 07:16 PM
ck1109
Oct 26, 2015 03:40 AM
mjnoles1
Car Care & Detailing
13
Oct 14, 2015 02:36 PM
