My next Mod; intake and HFC
Old 09-16-2015, 08:38 AM
  #31
VIVID
Pyroclastic Flow
VIVID's Avatar
John - Thanks for the clarity. I knew the various elements of the FI RHFCs, but you've put it together in a cogent package.
Sean
Old 09-16-2015, 08:48 AM
  #32
Ryne
The Steering Wheel Guy
Ryne's Avatar
Another vote for Takeda. Easy install with the benefit of long tubes. I wouldn't worry about metal tubes getting hot during hot city driving since that's not when you are trying to utilize the extra power the intake provides.
2012G37 (09-28-2015)
Old 09-16-2015, 08:55 AM
  #33
djdiskino
djdiskino's Avatar
Just to chime in OP, I am in the same boat with my sedan. I currently have aFe drop in filters right now. I am thinking of going to R2C Black Nickel finish with the Black Hex filters. (Thanks Rochester, they need to pay you for advertising their product so well!)
I owned an R2C intake before and they sound great (main reason I am getting an intake) I miss the sound. The compromise of some intakes as I have had long tube and short-ram previously is the long tubes you'll see the power-band shift so you may lose some low end peppiness to your car if you do a lot of stop-and-go traffic. That was my main reason to switch back to an SRI. R2C was my happy spot with my old Maxima.
At the end of the day it's to each his own but I thought I'd throw in my experiences as a daily driver that doesn't plan on tracking his car or worried about dyno numbers. Just have fun
Old 09-16-2015, 03:59 PM
  #34
2012G37
2012G37's Avatar
Adding them won't make any difference on CEL whatsoever. There is no relationship between one or the other.
It's been my second-hand research (and my personal experience) that FI cats simply don't register out-of-range on the O2 sensors. Part of that has to do with the J-shaped design of their connector. Another is that FI uses a catalytic converter with a 300 cell-count, opposed to the more typical 200 cell-count found in other high-flow cats. In other words, there's more surface area for catalyst to do its job.
By that, you could argue that they are *less* high-flow than other manufacturers, and I suppose that's fair. Similarly, all high-flow cats are *less* high-flow than test-pipes. However, *all* HFC's are also less restrictive than the OEM parts, and there's a point of diminishing return here, where personal choices come into play. Personally, I think FI cats are the perfect compromise between OEM cats and test-pipes, while at the same time being a very high quality build for cats that actually function the way catalytic converters are intended.
The only flaw in FI cats is the lack of support for the retaining bracket. The absence of this connecting bracket creates a noticeable vibration at idle. This is more noticeable on the 6MT, because the engine isn't engaged with the transmission at idle, but it's there nonetheless.
Man, I've taken a brain dump all over your thread, LOL.
You shared alot of great info. I appreciate it and its useful for those who have similar questions.
Q.Gsxr (09-28-2015)
Old 09-28-2015, 06:40 AM
  #35
2012G37
2012G37's Avatar
Today, i'm 99% sure I will be ordering the FI RHFC. Questions; if I order the two extra bongs, should I have something connected to them right away. Or can the stay as is until needed. My concern is will air leak of of them if nothing is attached to them.
Second, Non polish or stainless steel?
Old 07-30-2016, 05:20 AM
  #36
2012G37
2012G37's Avatar
My saga continues, made the decision few weeks ago to purchase Gen 3 intake. It finally arrived this week and will be installed on Monday.
Old 07-31-2016, 12:58 PM
  #37
the_wolff
the_wolff's Avatar
You can buy plugs for the bungs for around $12. My local Advance Auto had them in stock when I lost one from my Berks HFC. It was definitely obnoxiously loud until I got that plug back in.
You should also buy 2 extra bongs, but that's a different conversation.
2012G37 (07-31-2016)
Old 07-31-2016, 10:59 PM
  #38
2012G37
2012G37's Avatar
I got and installed the FI RHFC, with out the 2 extra bungs a couple of months ago (which are great). Tomorrow morning I will be installing the Stillen Gen 3 CAI.
Old 08-01-2016, 02:43 PM
  #39
2012G37
2012G37's Avatar
Install completed!
Old 08-01-2016, 02:45 PM
  #40
2012G37
2012G37's Avatar
Splash shield was not not installed, should I worry about rain and snow?
Old 08-04-2016, 04:17 PM
  #41
IracknBack
IracknBack's Avatar
Nice! Looks great. How much of a PITA was removing the front bumper? I want to go intake now that I'm happy with my exhaust situation. Then a tune and i'll be done with power mods for quite awhile.
Great job.
2012G37 (08-04-2016)
Old 08-04-2016, 06:13 PM
  #42
MaQG37
MaQG37's Avatar
Great job.
Pretty easy to do, just tape off your bumper where it meets with the rest of your car so you don't scratch your paint. There is a DIY on this forum on how to do it.
Old 08-04-2016, 09:00 PM
  #43
2012G37
2012G37's Avatar
Great job.
I had a shop install for me. Which took about 2hours. ...
So far, it's awesome... it's especially after 4k rpm
Rick in NC
Intake and Exhaust
27
01-06-2019 09:47 PM
OneSickBlackG
01-06-2016 08:49 AM
drewfinity
09-24-2015 11:01 AM
luisalan
09-06-2015 05:45 PM
Quick Reply: My next Mod; intake and HFC
