Heat not coming out of center vent.
Old Jun 2, 2015 | 08:31 AM
Viet's Avatar
Viet
Heat only comes out of side vents but not center vent. AC comes out of center vent fine.
Is this normal in all sedans?
Old Jun 4, 2015 | 04:49 PM
Viet's Avatar
Viet
No one, has this problem?
Old Jun 4, 2015 | 04:56 PM
Viet's Avatar
Viet
Old Jun 4, 2015 | 05:14 PM
Diode Dynamics's Avatar
Diode Dynamics
What have you done to troubleshoot this issue?
Perhaps a few more details will help us pinpoint the problem for you
Nick C.
Old Jun 5, 2015 | 03:51 AM
Viet's Avatar
Viet
I'm just wondering if g37 sedans get hot air out of there Front center cents to figure out if it's normal or not.
Old Jun 5, 2015 | 07:06 AM
qmantran's Avatar
qmantran
It's not normal for any car to only put out heat for center vents only
Old Jun 5, 2015 | 05:42 PM
securityguy's Avatar
securityguy
Most all cars I've ever owned...heat comes out of the side and floor vents but not center FWIW.
Old Jun 5, 2015 | 06:19 PM
Flakman's Avatar
Flakman
AFAIK regardless of temperature, if you have your "MODE" set to blow at your face, all 4 dash vents work unless you manually shut down individual vents at the vents. If you set to floor only, then the dash vents will not work. If both, then floor and dash vents with less volume.
Old Jun 5, 2015 | 06:44 PM
securityguy
If you set it to auto it will do as I stated. Manual mode is something all together different.
Old Jun 5, 2015 | 07:08 PM
Flakman's Avatar
Flakman
I'll have to check that out. Rarely use auto.
Old Jun 8, 2015 | 11:45 AM
Flakman's Avatar
Flakman
In Auto or Manual, whether using heat or A/C, the blower blows through all console vents unless you have the individual vents closed off.
Old Jun 8, 2015 | 06:04 PM
telcoman's Avatar
telcoman
Did you try turning the thumb-wheel at the bottom of the vent
Someone may have closed it
Telcoman
Old Jun 8, 2015 | 09:55 PM
securityguy
Flakman, you are incorrect...at least as it comes to my 2012 car. On my car, with the system set to AUTO, if I crank the heat, the display shows that the air is now coming out of the floor vents only. If I crank the temp back down to cool, it then adjusts to only the top vents.
Old Jun 9, 2015 | 11:01 AM
Flakman's Avatar
Flakman
Interesting. I'll take a look again. To tell you the truth...it may have been much less from the vents, but it was warm, but I had not looked at the display. I'll have to do a more thorough check. Thanks!
ModInJapan
Engine/Intake/Exhaust
117
Jan 7, 2017 01:59 PM
ModInJapan
Brakes/Suspension
84
Mar 21, 2016 05:25 PM
ModInJapan
Brakes/Suspension
86
Mar 16, 2016 07:08 PM
snuka
Sep 2, 2015 09:27 AM
