What should I do next?
Old May 17, 2015 | 09:51 AM
G37Xiang's Avatar
G37Xiang
Hi I own a 2010 blue slate G37X non-sport Sedan and very new to this forum. Just wondering what should I do next
Currently have
Fast intention exhaust/test pipe
Stillen gen 3 intakes
Hotchki sway bars
White line end links
Fortune auto coilovers
Cusco front strut brace
Oem lip
Midnight grille
35% all around tints
blacked out all the chrome pieces and removed infiniti/g37x emblem
Thinking about getting
Set of wheels
Upgrade to BBK
Any other suggestion?
Old May 17, 2015 | 10:03 AM
Originally Posted by G37Xiang
Hi I own a 2010 G37X non-sport Sedan and very new to this forum. Just wondering what should I do next
Currently have
Hotchki sway bars
Oem lip
Set of wheels
Upgrade to BBK
Welcome to the site, sounds like you've been very busy w/ your G
Wheels depend a lot on your style preferences and budget, and since you plan on a BBK you'll need to confirm that your new wheel set will clear the big calipers.
The 18" SSRs in a 18x9.5 +45 clear the BBK, aren't too expensive and are a quality wheel
I'd give a look at this build thread, he's also got an X sedan and an upgraded BBK and happens to run those wheels
https://www.myg37.com/forums/build-t...d-journey.html
There's SO many wheel choices so some help w/ what style you like will make it easier for suggestions.
Old May 17, 2015 | 11:58 AM
dkmura's Avatar
dkmura
20 Year Member
I agree- the BBK and wheels must match up as far as wheel clearance. Nothing could be worse than buying them separately and finding there's interference. I'd suggest looking at a good set of lightweight 18" forged wheels when you do decide to purchase a set. There's more (and cheaper) tire choices, and the lower unsprung weight will help everything from acceleration to cornering in your G.
Old May 17, 2015 | 12:53 PM
G37Xiang's Avatar
G37Xiang
Thanks for the advice! Any other mods that I'm missing that is beneficial?
Old May 17, 2015 | 01:47 PM
RexHavoc's Avatar
RexHavoc
I'm noticing a difference after installing the m370 manifold. You'll likely need to tune shortly afterwards though.
Old May 17, 2015 | 02:05 PM
If you can keep your current Infiniti wheels for a winter tire set (assuming you live in a colder climate) then getting sticky summer tires w/ your new wheels will make as much of a performance difference as anything you can do to these cars (short of Forced Induction, that is)
Old May 17, 2015 | 02:58 PM
xnick101's Avatar
xnick101
Only one thing to do now. Twin Turbo time
