Need help with rear Fortune Auto 500 shock/spring install
#92
Shared experiences is what makes places like this great. I've been helped by so many people here too. There's no need for others to go through the same frustrating situations if you can share and give them a heads up. I'm glad that you, and whoever else, have benefited from sharing my experience. I'd love to see a picture of the car after the installation. Happy anxious waiting. Ha!
#93
I just got my coilovers from fortune auto today. I was so excited opening it all up. The top mounts have a couple minor scratches on them that happened during the shipping. Fortune said no way it got past their quality control check like that. They are sending replacement parts tomorrow.
LilRocket (03-06-2015)
#94
#95
As an update, I decided to go ahead and have a local shop look over the install and tweak it as necessary based on my ride height and comfort goals. After the tweaking that they did, it seems to ride a good bit better.
Also, I finally got the rear camber kit installed and then had the car aligned. It really seems like the car rides better after the alignment. It had a small (comparatively) amount of negative camber on the rear so I've been wondering if correcting what part of the tire contacts the road actually made a difference in ride quality. It makes sense that it could affect ride quality based on how the tire is made, but it could just be wishful thinking and/or pure coincidence.
The creaking noises have not gone away. Nothing I did and nothing that these guys did made the noise any worse or any less. I guess I'm just going to have to put up with it. Every now and then I'll get a creaking from one or the other front coilovers too but I'm just going to have to let that go too it seems.
Thanks again for all of the help and advice! It is greatly appreciated!
#98
The creaking noises have not gone away. Nothing I did and nothing that these guys did made the noise any worse or any less. I guess I'm just going to have to put up with it. Every now and then I'll get a creaking from one or the other front coilovers too but I'm just going to have to let that go too it seems. Thanks again for all of the help and advice! It is greatly appreciated!
Not sure if the creaking noise is occurring in the same place but it very well could be. I'll be doing the same when I install my set just to help reduce any noises between those two surfaces.
#99
1 being similar to (stock*) and 5 being very stiff and bouncy.
I'm most excited to get rid of that feeling of bottoming out on my swift lowering springs. That **** gets annoying.
#100
I experienced a similar noise on the TSX I owned with coilovers. To help remedy the noises, I custom made gaskets that sit between the upper coilover mount and the chassis to help eliminate creaking noises. It does help.
#101
How would you rate the ride comfort compared to stock or stock shocks + lowering springs?
When I ordered, I told the guy that I wanted the most comfortable ride as possible so he recommended 10/8 springs and comfort valving. My front dampening is at 7 clicks from the softest/lowest setting and the rears are at 5 clicks from the softest/lowest and it is a good ride. Definitely not as soft as stock but definitely not stiff and bouncy.
#102
I've not run this car on just springs. I went from stock to coilovers. However, I don't have a bottoming out feeling at all.
jsampsell (03-16-2015)
#103
All,
I spoke with Jenn at FA this morning to get some additional information regarding valving and spring sizes and rates and she provided the following:
Custom Valving
Spring Rates and Sizes
Custom Valving
- Can be had per your request
- Comfort, Street, Track, etc.
- Just specify what you will be doing most
- FA Recommends 11k/8k for G37 Sedan
- 7" rear Swift spring > Will drop 1.5" - 3.0"
- 8" rear Swift spring > Will drop 0.75" - 2.5"
#104
All,
Custom Valving
Custom Valving
#105
Just to close the loop on my journey with the Fortune 500 coilovers.I opted for the Swifts spring 11k/8k spring rates and 8" rear springs. I also had SPC front and rear camber kits, Hotchkis sways, new end links (Whiteline rear, Moog fronts) and a Cusco STB. The rear ride height is perfect 1.5 finger gap, there is plenty of adjustability to go lower or higher by about a full inch. The ride quality is 9/10, handling 9/10 and the noise isn't bad from the camber bushings. They squeak a little, but you can barely hear it when the radio is off and no one is talking. Overall I'm 10/10 satisfied and would recommend this combo to any X sedan owner.
