Looking at buying a G37X
The trunk organizer I'm referring to I think came with the first aid kit, and took the place of the car jack and tire tool organizer I now have on the G37. I don't think I can find anything that custom in shape 3rd party. So for now, my trunk has a tire repair kit and compressor in it. May go back to a tool box to keep it...
As for the CVT, different strokes. I find it quite pleasant to drive. I'm finally getting used to gears again after 10 days with the G.
I've found that when I floor it up to 60mph then let off the gas, my G doesn't know what to do for a moment. It's still expecting me to drive it hard all the way to 100mph, and takes awhile to upshift to a cruising gear and my rpm are over 4k for a bit before it settles down.
I totally understand why this happens, but the CVT never acted like this. It was much more fluid.
I'm thinking about adding paddles so I can quickly force it to top gear shortly after accelerating hard. I had paddles on the Maxima, but didn't use them much. Now, with a real transmission, I can see them being more useful.
I have a stack of the 4DSC stickers I bought for the meet and then didn't get until afterwards...
As far as the paddles, using the shifter will be much more responsive. The lag with the paddles is slightly more for whatever reason. I cleaned my throttle bodies, installed a grounding kit and reset my ECU. That all seemed to help my trans become more responsive. Hoping a tune will clean it up more.
I didn't know that. If I thought ahead, I really should have done that... all things considered. Good intentions from you though, Chris.
As for the paddles, I am pretty sure that simply tapping the downshift paddle is faster than taking my right hand off the wheel, putting the shifter into DS mode, and then pulling back to downshift. If not, then the paddles are essentially worthless, unless you're racing and really don't want to take your hands off the wheel.
And if you leave your right hand on the ratchet shifter when shifting, then problem solved. Personally, moving my right hand off the steering wheel is the only way I can change gears in my car, so that argument seems kind of silly to me.
You don't put it into DS mode every time you change gears.
And if you leave your right hand on the ratchet shifter when shifting, then problem solved. Personally, moving my right hand off the steering wheel is the only way I can change gears in my car, so that argument seems kind of silly to me.My 2012 Maxima with Sport package got me used to 2 years worth of paddle shifting, and I have very specific times when I find myself trying to tap the downshift paddle...I then remember that I no longer have this feature. It's almost worn off but I find myself wanting it at times...
So to recap, I am driving along in D, and I hit a hill...instead of giving it more gas to force the downshift, I simply "blip" the left paddle. How could this possibly take longer to downshift than the procedure I described above?
Comparing your 6MT to my 7AT is also silly, don't you think? Of course you have to remove your hand from the wheel, and your left leg (which is probably stronger than your right) also has to do a little song and dance as well. I personally like the little "blip" tap of the left paddle to get me where I want to be.
I admit that a 6MT would be really fun to own...but I would never do it as a daily driver (thus I'd probably get the coupe). I don't work from home, and I put at least 40-50 miles per day on my car...a good bit of it can be stop and go until I get to certain spots. I'm done with manual transmission cars...unless it's a toy. If it's something I drive now and then, sure...but not my daily commuter.
Wait...that's all you can say after all I wrote? How about some substance? Or do you agree with me now that you see my inended use for the paddles?
Post edit...I'll answer that by saying refer back to my post above. I want RPM to go up without giving it more gas. Now how about some commentary...
Wow, you are a lot quicker than my ninja edits.
But man did you make me ROFL with that reaction. Too funny.
No, I don't agree with you. I manage engine speed with the throttle in sync with gear shifts (when done right LOL), not the other way around, which is how you describe it here. As for commentary, I think flappy paddles are a ridiculous toy in average, consumer-grade vehicles, who's only purpose is marketing. And on a CVT... puleese.
That said, I've driven the 7th Gen Maxima many, many times. And I will admit that Nissan very effectively spoofs the driver into thinking there are separate gears in that transmission, when that's the experience they want in the car. But if that's truly the case, then they bought the wrong car.
There. Commentary.
But man did you make me ROFL with that reaction. Too funny.No, I don't agree with you. I manage engine speed with the throttle in sync with gear shifts (when done right LOL), not the other way around, which is how you describe it here. As for commentary, I think flappy paddles are a ridiculous toy in average, consumer-grade vehicles, who's only purpose is marketing. And on a CVT... puleese.
There. Commentary.
There. Commentary.
There. Commentary.
You have the luxury of giving it as much gas as you want and maintaining a gear. I can only do that in DS mode while shifting manually. Since I have a D mode...the most effective way to get into the power band (yet not use it right then and there) is by using paddles. The next best way is to move into DS mode, which has already defeated the purpose of leaving it in D.
If I was launching and wanted manual control, I'd manually shift in DS mode (ignoring paddles). I am however referring to daily crusing around in D...and then deciding I want to get close to the power band. I'm not sure you can relate exactly. How many miles have you put behind an 7AT G37?
Not a luxury, just is what it is, which was a conscious choice to find a (relatively rare) G37 Sedan with a 6MT.
Total miles in a G37 7AT? IDK... a few hundred, tops. Test drives and loaner cars.
With the 7AT in D mode, you can't do that...
Well, I suppose if you had paddle shifters you could. I don't always want to give it extra gas to force the downshift, and I don't want to drive in DS mode all the time either.
The paddles have a very specific purpose, and I feel that it's to allow shifting quickly without taking hands off the wheel...specifically in D mode...(DS mode too I guess).
Precisely. Do you ever downshift in anticipation of needing the lower gear, but you don't quite punch it yet? When I plan on passing, I'll go ahead and get into the gear I feel is needed, and when the opportunity presents itself, I'll gun it.
