cruise control
cruise control
I wanted to know if any of you had this problem with the cruise control were when driving it shut down or the number just flicker all the time?
I had that problem before and I brought it to the dealer and apparently had a new one but this one is doing the same thing??
Since I dont know how to add a video here, here's the link to youtube
any advice would be appreciated.
tks
tks
Mine flashes when I have the cruise control on but I'm driving over the set speed. For instance, if I have it set at 75 and I'm going down hill and speed up to 77 it'll start flashing. As soon as it goes back to the set speed it stops flashing. I have the ICC so I don't know if that helps.
I will bring it to the dealer again.
Same thing happened to me this morning. No ICC. It is a MT. It happened on the way to work so I've not had a chance to see if there is a standby code. I'll do that when I get home.
BB I've googled and searched the Infiniti parts website and nothing for clutch interlock switch comes up. Does Nissan call it something else?
So the update is when I got home there was a standby code of P0605, can't remember word for word but something faulty with the internal ROM in the ECM. Called the dealer prior to clearing the code just to make sure that I shouldn't bring it directly in. Service manager told me to clear it to ensure it wasn't a gremlin and if it comes back to bring it in for a look.
Guess I'm in a wait an see mode.
More Information for AIRTEX / WELLS 1S5532
It's called the cruise control release switch. I just ordered one recently because I broke mine while installing the RJM pedal. If you get down in the foot well with a flashlight you can look up and see if it's broken or not adjusted properly. When the pedal is all the way up there is a white bumper that must fully depress the switch. If it's not depressing it enough, the car senses that the clutch pedal is depressed and won't engage the cruise control. But it doesn't sound like that's your problem.
I'm going to check codes everyday when I get home to see if the same code comes back. If it does, then I'll let the dealer mess with it. I also found a TSB for P0605 on 2009 G's that they solution was replace the ECM. To be honest I think Nissan has no clue what causes the issue.
hmm I got a 6MT and I have installed the softer clutch spring shortly after I got the car, may the spring make the cruise control release switch sense that the pedal isn't fully depressed ? I took the car to the dealer with this issue twice and they couldn't fix the problem I've been having :/ May that be the possible issue I have been having with my CC?
m3clubracer
Sep 20, 2015 09:20 PM
