Maintenance - Other
Old Apr 27, 2013 | 11:31 AM
GeezerB's Avatar
GeezerB
Maintenance - Other
The attached photo is what I am greeted with every day. I read the manual & deactivated this warning via the nav screen but it still shows up. What am I missing? Quite annoying.
Old Apr 27, 2013 | 01:22 PM
NJ Torque's Avatar
NJ Torque
You need to reset it via the square and circle buttons on the right side of the cluster.
Old May 2, 2013 | 03:33 PM
Quad B's Avatar
Quad B
I too have had this issue anybody know why it occurs? And I remove it and it comes back every time I turn the car back on,I'm pretty sure I'm doing it wrong? Thanks
Old May 2, 2013 | 03:59 PM
The car cannot be moving.
Use the buttons on the right side of the instrument hood. One cycles through options, the other is the "enter" button. Cycle through until the page with Maintenance comes up. Use the other button to scroll down until its highlighted. Select it. When the maintenance screen comes up you can reset the miles counter or reset the mileage interval for the alert. Set the alert interval to 0. Scroll to the "back" option and back all the way out of the screen. Done.
Old May 2, 2013 | 04:09 PM
SAL9000's Avatar
SAL9000
Just to clarify the helpful posts above, the dash reminders are separate from those of the LCD infotainment screen, which means each has its own reset procedure.
Old May 2, 2013 | 05:36 PM
rlo's Avatar
rlo
I cant figure out what Nissan/Infiniti was thinking with these reminders. The LCD and dash are independent of each other and both dont let you put in notes, e.g. oil, differential, coolant, etc... All you see is you have maintenance #.
Has anyone found useful way of setting these?
Old May 2, 2013 | 06:22 PM
thestumper's Avatar
thestumper
The Flux Capacitor needs adjusted.
Old Mar 29, 2020 | 09:34 PM
Billy Sabillon's Avatar
Billy Sabillon
How do you switch the miles back to 0? And what does the other option mean?
stealth210
General Tech Questions
27
Jul 26, 2017 06:48 PM
Victory
Oct 28, 2015 01:43 PM
dedmanchan
Oct 6, 2015 05:43 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Victory
Sep 28, 2015 10:49 PM
