09 G37s 6MT idle RPM question/help
Old Mar 9, 2013 | 12:06 AM
Steve_A_Leeve's Avatar
Steve_A_Leeve
Question 09 G37s 6MT idle RPM question/help
Hello all,
I bought an 09 G37s sedan back in January and am still getting used to it, but loving it so far. However, I've noticed several times that while in idle, the rpms will sometimes drop slightly, causing the engine to feel like it is about to stall. the rpms at idle are at 800. Does anyone have a cure for this?
thank you
steve
also,
The assist spring has been removed because the long top pin broke off while attempting to install the better spring that was bought off this forum, so if anyone has an extra assist mechanism lying around or just the top part with the long pin that goes through the spring, please let me know
Old Mar 9, 2013 | 12:31 AM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
I experienced something similar recently with my G and others recommended that I clean my throttle bodies and it fixed the problem. Here is the DIY thread. Hope this helps.
https://www.myg37.com/forums/d-i-y-i...le-bodies.html
Old Mar 9, 2013 | 01:41 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Might want to ask on the 370Z site. Maybe someone that's installed the rjm pedal will sell the stock one cheap.
aliiin
Apr 27, 2018 10:37 PM
the dreame
Apr 9, 2017 10:30 AM
moy92
Aug 20, 2015 08:43 PM
Jeebus
Aug 1, 2015 10:26 PM
