Wierd Hot Start Issue: 2012 G37 Sedan 7AT
Old Aug 2, 2012 | 02:57 PM
Mike S.'s Avatar
Mike S.
Hey guys,
Have a weird problem that the dealer is having a hard time fixing. My 12 G37S Sedan 7AT, has a hard time starting/long crank when hot (engine temp hot). So, if I drive, then park, then start 90 mins later, I get a long crank that eventually gets the car started. Opposite...when cold/ambient temp in the morning, the car starts TOO quickly, hard to tell...but it doesn't crank the normal 3-4 times.
Somethings up....just started happening one day.
Any thoughts?
So far the dealer attempted fixes:
1. Run a 3-4 tanks of gas through...no better, so not bad gas.
2. Bled fuel line of air...no better.
3. Software update for my 12(???)...no better (but I'm curious what was updated)
4. Check/tighten engine grounds...no better.
Be nice...they're probably reading this.
Mike S.
Old Aug 3, 2012 | 02:00 PM
00Max00's Avatar
00Max00
Sounds like leaky injectors.
Old Aug 3, 2012 | 04:29 PM
mikeb2004's Avatar
mikeb2004
Maybe bad coolant temperature or air temperature sensor, or their connections/contacts? Perhaps one of them isn't sensing right when it is heat-soaked (that's NOT unheard of), and as a result the ecu is using wrong fuel mixture or timing for hot start. Could also be fuel pressure regulator related.
GW330
Feb 2, 2024 05:41 PM
ericmadGRR
Apr 26, 2016 01:27 AM
Raye D. Ater
Nov 9, 2015 12:58 PM
pledes23
Aug 11, 2015 10:54 AM
Madorable
Aug 8, 2015 11:13 PM
