I need help!!!!
Old Nov 18, 2011 | 06:56 PM
brklynempire's Avatar
brklynempire
Question I need help!!!!
How to change the front Turn Signal In my G37 sedan Thanks
Old Nov 18, 2011 | 10:31 PM
NCHIINFMNGR's Avatar
NCHIINFMNGR
If it is burnt out, just go to dealer to replace, free, other wise from what i remember, if u can not access it from up top, you have to reove thw wheel and inner fender well plastic, the u can get to the back of the headlamp assy
Old Nov 19, 2011 | 07:45 PM
rpkg37xs's Avatar
rpkg37xs
when i did mine i had to remove the front wheel, inner splash shield and a few 10mm bolts from the bottom bump. removing the wheel does make it easier to do gives you more room to work. i did the marker light and turn signal bulb both with piaa bulbs. i heard you can do it from the top by removing the air boxes.
Old Nov 19, 2011 | 08:15 PM
djguy23's Avatar
djguy23
Go though the wheel well..you can access the whole headlight unit
Old Nov 19, 2011 | 09:06 PM
brklynempire
wow all the work for headlights
Old Nov 21, 2011 | 03:40 PM
eksigned's Avatar
eksigned
damn -- search dude.
Old Nov 21, 2011 | 07:15 PM
rpm&my_G35's Avatar
rpm&my_G35
we have a DIY section:
D.I.Y. Installations/Modifications - MyG37
https://www.myg37.com/forums/d-i-y-i...placement.html
