custom DRLs
Old Apr 16, 2013 | 08:51 PM
  #31
nycjoker's Avatar
nycjoker
OP, can you plase post an up close photo of the fog lights with the LEDs? I'd like to see how they look head on up close. Thanks!
Old Apr 17, 2013 | 02:14 PM
  #32
elrey85's Avatar
elrey85
Just thought of an idea. You can also have the LED strip run on the bottom of the headlights with out drilling. After looking at the headlights, you can stick the strip on the bumper right where it meets the headlights. There is just enough room to stick LEDS in there starting from the inside of the headlight where the turn signals are. Now to run the wires, there is just enough clearance right in the inside of the headlight where the turn signals are and it meets the bumper. If you look closely there is just enough clearance for a small wire that you can run behind the bumper and just run it to the battery. My only concern is the LEDS are going to be facing upwards and not outwards like they usually are, because of the mounting room on the bumper where it meets the headlights. So basically I am not sure how it will look if the LEDS are facing upwards and the car is coming towards you. Hmmm
Old Apr 17, 2013 | 03:13 PM
  #33
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Like this? Hopefully not, I was sure that this style had finally phased out.
Old Apr 17, 2013 | 03:42 PM
  #34
elrey85's Avatar
elrey85
Audi A5 R8 Style LED Strip Light on Infiniti G35 - YouTube
Yes that is exactly the style I am talking about but just outside the headlights and mounted on the bumper. The guy in the video actually opened up his headlights and modded them but same style. Yes the style is old but it is just personal preference and the idea is outside the bumper/headlights without any drilling. I do however also like the OP's idea on the foglight bezel and will consider it when I do this mod in person.
Old Apr 17, 2013 | 05:32 PM
  #35
LOLURMAD's Avatar
LOLURMAD
The only way to do DRL's is to have them done professionally with quality parts. Not those cheap LED strips and what not.
Here are my lights done by ONEighty
Old Jul 23, 2013 | 01:39 AM
  #36
Samer Serhan's Avatar
Samer Serhan
Quick question; i have a g37 here in canada, and some form DLRs are a must
That means there probably is a DLR wire I can tap into and use these:
http://www.ebay.com/itm/WHITE-12-LED-SIDE-SHINE-HEAD-LIGHT-STRIP-DRL-HEADLIGHT-STRIPS-B5-/160710020688?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item256b104e50
Directly without using a relay switch?
Am I right to think this?
Thanks!
Old Jul 23, 2013 | 03:50 PM
  #37
DJE44's Avatar
DJE44
Get the official Infiniti DRL's. Bright as hell and warrantied after they install. A bit pricey, but you won't be disappointed.
ANMVQ
Dec 8, 2016 04:55 PM
Landshark
Sep 29, 2015 11:20 PM
pcwd
Sep 15, 2015 10:06 PM
