my car runs so fn heavy
Old 09-10-2011, 06:48 PM
  #61
TinsleyC
TinsleyC's Avatar
What is an accelerator position reset?
On my car, all the power feels like it's in the first 1/4 of the pedal movement. It would be nice (I think) to spread that out a bit...
Old 09-10-2011, 07:29 PM
  #62
1BadAssG
1BadAssG's Avatar
Accelerator Pedal Released Position Learning DESCRIPTION Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE 1. Make sure that accelerator pedal is fully released. 2. Turn ignition switch ON and wait at least 2 seconds. 3. Turn ignition switch OFF and wait at least 10 seconds. 4. Turn ignition switch ON and wait at least 2 seconds. 5. Turn ignition switch OFF and wait at least 10 seconds.
Old 09-10-2011, 07:52 PM
  #63
Doggy
Doggy's Avatar
Hey op your tire sizes are tractor sizes! Get a 275/35 for the rear And the front a 245/40
Old 09-10-2011, 08:16 PM
  #64
RISKY GUY
RISKY GUY's Avatar
The loaner is probably a g37x with 17s inch rims.
Less weight & smaller rims.
And is also 200 lbs lighter, if i am not mistaken.
Old 09-10-2011, 08:24 PM
  #65
1BadAssG
1BadAssG's Avatar
I'm actually realizing that. The fn discount tire guy said that it wouldn't make a difference. I order 245/40/19 front and 275/35/19 rear, but the douche called few days latter and said that he can't get those but can get these. He said that these tires are practically same size but very small margin of difference.
Also the loaner was not and X. It was a journey with 17s.
Old 09-10-2011, 08:51 PM
  #66
pauliewalnutzz
pauliewalnutzz's Avatar
I never knew they had this. Ill try it on my car tomorrow, it cant hurt anything. How would you know if the process you did went through? Is there a flashing light or something to confirm it??
Old 09-10-2011, 09:06 PM
  #67
mikelebron
mikelebron's Avatar
Ya know.. Ive had my car for 700 miles and it feels heavy on hot days.. I have to say... This car heats up fast! My bmer took about a solid 5 minutes og hiway driving for it to heat up.. This car is hot just by pulling down my block.
Old 09-10-2011, 09:09 PM
  #68
pauliewalnutzz
Heat Soak my friend Good thing its starting to get cool in the New York area, my car came alive again!
Old 09-10-2011, 10:01 PM
  #69
MACS
MACS's Avatar
Originally Posted by sniper27
the 19s will make a difference. switching back to 17s will feel much smoother and "lighter", as they should be.
I haven't read all the posts yet, but this is what I thought right away. Heavier wheels and tires is a whole lot of added unsprung weight which will make the "butt dyno" tell you it's driving heavy... because it is.
Old 09-11-2011, 03:49 PM
  #70
Received 4,941 Likes on 4,174 Posts
Those tires are an inch larger diameter (you had me scratching my head when you said 5 inches, lol) and you speedo will be 2mph slower at 60 mph. It's over 3% difference from the stock size so you may run into Traction control & ABS issues, plus your speedo error.
I'd definitely raise some hell at the tire shop, they shouldn't be selling you tires over 3% different +/- unless you specifically request it.
Old 09-11-2011, 04:40 PM
  #71
eksigned
eksigned's Avatar
Post a video?
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
WolfSongX
Car Care & Detailing
05-10-2017 07:26 PM
chuckie311
78
04-18-2016 08:56 PM
Thedbarz
33
02-09-2016 12:05 AM
JakeG37
08-02-2015 12:00 PM
Quick Reply: my car runs so fn heavy
