my car runs so fn heavy
Old 09-08-2011, 12:54 AM
1BadAssG
1BadAssG's Avatar
I think so that it is probably the cause of tires. I'm changing back to my 17s tomorrow and see if it'll make any difference
Old 09-08-2011, 01:49 AM
maxfinity
maxfinity's Avatar
I have a 2010 w/ about 24k miles and it used to feel heavy to me as well. So I started driving it like I stole it and now it feels just as quick as it used to be. A few fast take offs from a stop usually lightens the feel. But i do notice it starting to feel heavy again when I'm in heavy traffic. Just the nature of the beast.
Old 09-08-2011, 02:08 AM
sniper27
sniper27's Avatar
the 19s will make a difference. switching back to 17s will feel much smoother and "lighter", as they should be.
Old 09-08-2011, 08:01 AM
mikelebron
mikelebron's Avatar
You babied it too miuch during break in. I don't condone going to red line or flooring it during break in but a heavy foot is far better than grandma driving. There are too many scientific articles on how to properly break in a car of todays generation and all point to a more aggressive approach over manufacture ways.
Since your past the break in period get an injector flush done. Also clean the throttle body.. Probably a ton of grandma driving carbon build up... Then drive it like you stole it for 1k. Also change your air filters... Guarantee it will come back.
Old 09-08-2011, 09:54 AM
1BadAssG
1BadAssG's Avatar
Good points there. I see that there's a guide for throttle body cleaning, and I can change the airfilters myself but how do I injector flush? Is it the one that you put in the gas tank?
I have not babied the car at all. As a matter of fact, I've driven it 20,250 miles in 10 months and about 60% of that is me stepping on it hard. It just feels doll now. No soul in the car and it has hard time going over 3000rpm
Old 09-08-2011, 10:23 AM
mikelebron
mikelebron's Avatar
Injector cleaning should be done by a professional as they hook up directly to the injector lines and force in the solution under high pressure. Dealer or qualified mechanic - I know Jiffy Lube does this but not recommending them. The fuel additives probably would be fine but could not comment on their effectiveness over the high pressure / high volume approach...
Also you using premium fuel all the time?
Old 09-08-2011, 10:50 AM
Chi-City-G
Chi-City-G's Avatar
Change the air filters... it seriously may be as simple as that. I would also recommend driving it a bit spirited as well but if you have not changes the filters yet, simply do that and see if that was the issue and let us know!
Old 09-08-2011, 11:08 AM
1BadAssG
1BadAssG's Avatar
Today I will be doing a full tune up to see if the car will come back. I'll reset the ecu, Mobil 1 oil change with K&N oil filter, airfilters, fuel injector, and probably throttle body cleaning.
I just hope that it comes back to me and if not, then ill give it one more go by changing back to my stock 17s and if all fails then a trip to the dealer is on my fortune.
Old 09-08-2011, 11:11 AM
1BadAssG
1BadAssG's Avatar
Yes I've always used 91 chevron
Old 09-08-2011, 12:05 PM
Austin713
Austin713's Avatar
the 19s do make a difference, not by much but that is what you are feeling. you should see a noticeable difference after installing new filters and oil change if youve never changed them before and youre at 20k. they are probably pretty dirty.
Old 09-08-2011, 12:10 PM
hadokenuh
hadokenuh's Avatar
Yeah, do the fuel injector service and throttle body cleaning. I had mine done at 30K and could feel the difference in both performance and smooth idle. I am at 50K and plan to do it again at 60K.
And yes, swapping the wheels/tires should be your last option
Old 09-08-2011, 12:39 PM
1BadAssG
1BadAssG's Avatar
I do regular oil changes every 5000 miles with Mobil1 and oil filter.
the only thing I haven't done is the airfilters.
Old 09-08-2011, 02:10 PM
kaoticdemize
kaoticdemize's Avatar
the loaner car you drove has been most likely 90% driven hard, hence the quickness of the tranny. if your in manual mode and it still feels bogged down then you definitely have an issue. Did you get the tranny update by chance?
Old 09-08-2011, 02:27 PM
  #29
gugarci
gugarci's Avatar
Originally Posted by hadokenuh
Yeah, put it in DS or M mode and drive it like you stole it. It'll come back
I also think the bigger tires and wheels you have make the car feel heavy. Especially when you up-size the tires. Do you happen to know how much your tires weight?
I agree, was ready to post this myself till I read this post. The bigger tires are probably a little heavier than the stock not enough to feel a difference. My bet is on the wheels. Unless you spent a fortune on wheels I'm betting your new wheels are much heavier than your stocks.
Old 09-08-2011, 02:54 PM
  #30
dseltz
dseltz's Avatar
My dealer said the that ECU reset, while making the gear changes more smooth, also results in less apparent performance. Could it be that the loaner cars don't have the ECU change?
Quick Reply: my car runs so fn heavy
