rear view mirror vibrates
Old Sep 2, 2011 | 10:21 PM
manbeing's Avatar
manbeing
when speed is over 50 mile, the rear view mirror vibrates. does it happen on my 2011 G37x only?
Old Sep 2, 2011 | 10:51 PM
757G37's Avatar
757G37
Ive never had that problem with mine.
2010 G37xS
Old Sep 2, 2011 | 11:01 PM
sniper27's Avatar
sniper27
mine only vibrates when the music is up loud.
Old Sep 2, 2011 | 11:33 PM
Silver37's Avatar
Silver37
Hmmm...that is a typical sign of a bad driveshaft. Hopefully that's not your problem.
Old Sep 3, 2011 | 09:28 AM
financeman's Avatar
financeman
mine too......
Old Sep 3, 2011 | 11:34 AM
superjer2000's Avatar
superjer2000
Yours is not the only one. My 2010 does the exact Sure thing. There are others on the forum as well.as there has been at least one other thread. Nothing to do with 9 driveshaft problem which I am sure would have a lot worse symptoms. I haven't taken mine in get as I rarely need to drive that fast on my Commute.
Old Sep 3, 2011 | 01:08 PM
rpm&my_G35's Avatar
rpm&my_G35
The rear view mirror in my 07 G35x vibrated when the music was loud but it doesn't in my 11 G37s.
Old Sep 3, 2011 | 06:25 PM
MR.T's Avatar
MR.T
Yep I have the exact same car and mine vibrates always on the highway. Its annoying!
Old Sep 6, 2011 | 08:39 PM
Djfarhan's Avatar
Djfarhan
negative here
Old Sep 7, 2011 | 08:50 AM
Chris11LE's Avatar
Chris11LE
Do you feel a vibration anywhere else?
Mine did the same thing and it *was* the driveshaft issue....there is a TSB out about how it can be fixed. My rear view mirror vibrated (at 75/80mph you basically couldnt use it to see behind you), but so did my brake pedal and you could also feel it in the floorboards and drivers seat.
Old Sep 7, 2011 | 03:37 PM
manbeing's Avatar
manbeing
did you happen to remember TSB number? thanks!
Old Sep 9, 2011 | 10:29 PM
Silver37's Avatar
Silver37
Interesting...mine statement that it was the driveshaft was based totally on experience. My first car had universal joints that went out, and the mirror was unusable at 40 or so. Also felt vibration in my seat. That was a LONG time ago, but the principle is still there. Imbalances like that happen in harmonics, so it typically would happen again at 80 mph, similar to what some of you are are reporting. Sorry to hear it's actually a problem.
Old Sep 9, 2011 | 11:29 PM
Chris11LE's Avatar
Chris11LE
In the case of the TSB its actually one of the joints being STUCK and not allowing full travel of the "rebro joint" (which I think is a fancy version of the driveshaft yolk on old school RWD cars). At rest, on flat ground, the joint cant reset to its rest position so you get the vibration. Oddly enough it will go away on bumps and bumpy roads because the suspension is bouncing up and down and actually releasing the tension on the stuck joint.
The TSB number is ITB11019 "SB G37 AWD; Vibration And/Or Booming Noise At Highway Speed". The fix is pretty simple I think, they remove the bolts holding the joint to the rear diff, free up the joint and make sure it has full range of motion, then replace with new bolts torqued to the correct amount in the correct order. It seems that they may have no been torqued in correct order from the factory and it caused the joint to be cocked to one position instead of having full range of motion. Now the question becomes if it causes issues down the road, but who knows. My car had the issue for 500 miles (basically the trip home from where I bought it), luckily the dealer I went to has good techs and they figured out the issue.....interestingly enough even before Infiniti released a TSB on it.
Old Sep 15, 2011 | 04:55 PM
manbeing's Avatar
manbeing
Thanks for your info.
Old Aug 12, 2015 | 04:35 PM
m3clubracer's Avatar
m3clubracer
I think this is my problem
