Is the G37 Sedan meant to be driven hard?
Old 05-31-2011, 01:45 AM
  #31
ozzypriest
ozzypriest's Avatar
Originally Posted by KLB
Yes I do. The UOAs for the PU were great. I run it 7500 miles, and Blackstone said it would hold up longer if I wanted.
Me too, after I saw the OAs from Blackstone. Love that oil, engine runs great, and it no longer sounds like a diesel after hard runs. PU is great for our cars, apparently, even though it contains no esters. But I think PU is great for every car most likely. But it certainly seems to work well with our insanely close frictional tolerances.
Old 05-31-2011, 09:13 PM
  #32
Mudgen
Mudgen's Avatar
Where do you guys buy your Pennzoil Ultra, and what do you pay? I had to search quite a bit to find it at Advance for $7.78/qt. The Pennzoil site "oil locator" turned up only service facilities, not retailers.
Old 05-31-2011, 10:17 PM
  #33
financeman
financeman's Avatar
Have you checked Walmart?
Old 06-01-2011, 08:30 AM
  #34
Mudgen
Mudgen's Avatar
I can't turn it up on WalMart.com, have not physically been in the store to look for it. Have you gotten it from WalMart?
Old 06-01-2011, 06:07 PM
  #35
KLB
KLB's Avatar
Wal-mart. It was like $27 for 5 qt jug
Old 06-01-2011, 10:36 PM
  #36
g37brad
g37brad's Avatar
I have a question regarding this...
When can the car be driven hard? I was always curious when the car is ready to be driven hard, in terms of when you start it.
After a certain amount of miles? certain amount of minutes? operating temperature? I always see my neighbor in the morning turn out of our neighborhood and gun it. I usually keep it under 3k until I get on the highway which is 3 miles north of me, and about 10 minutes through traffic.
Old 06-01-2011, 11:22 PM
  #37
Received 4,941 Likes on 4,174 Posts
These cars warm up pretty quick, once your temp gauge is in range (takes just a couple minutes) the car should be warmed up just fine to get your foot in it.
Old 07-15-2011, 06:00 PM
  #38
kaktus
kaktus's Avatar
a more interesting question for me would be:
should the car be driven hard during break in (first 1000miles or so) or driven as per the instruction manual?
I've seen some posts where "experts" claimed that the best way to break in our G's or any high performance car is to drive it like you stole it.
I've seen suggestions that the car should be cycled to 5000rpms on each gear up to 7th and then use engine breaking to bring it back down again dropping gears each gear @ 3000rpm. This apparently should be repeated for 50kms then the engine switched off and left to cool and the oil drained and replaced with new oil.
Old 07-16-2011, 12:39 AM
  #39
jddssc121
jddssc121's Avatar
um no...
Do not confuse coolant temp w/ oil temp, two very different things. install or ride with someone who has an oil temp gauge--- you will be surprised how long the oil remains below operating temp once the coolant is warmed up.
Old 07-16-2011, 12:41 AM
  #40
jddssc121
jddssc121's Avatar
Originally Posted by irrelevant
The transmission is supposed to downshift aggressively when in drive sport mode. Don't like the aggressiveness? Keep it in Drive.
The car is built to be driven. Do so safely.
i was going to respond with the exact same thing until i saw your post.
"IT'S DOES IT ON PURPOSE"
Old 07-16-2011, 12:15 PM
  #41
G37CPA
G37CPA's Avatar
Originally Posted by matchan
Thanks guys. Im glad that my spirited driving is not really abusive to the car. I want to keep her for atleast 5 more years and maintain her in top form.
Any other inputs ?
Does your car sit out in the sun and/or freezing weather? What caused the leather seating surface to crack?
What exactly is hard driving then ? I dont care about replacing brake pads or tires but dont want to mess up the tranny , engine or other high dollar items
Hard driving is frequent readlining, and doing burnouts and donuts.
Old 09-13-2011, 12:37 PM
  #42
blackhawksfan81
blackhawksfan81's Avatar
Drive it gently until the car is fully warmed up. Just like your girlfriend or wife
Seriously though, here are my thoughts:
The vast majority of engine wear occurs on startup, nothing you can do about that. Keep your fluids changed at or before the recommended schedule and you'll be fine.
Brakes and tires (and to a point, suspension components) are disposable. Use them, enjoy them, and replace them when necessary.
Excessive bumps and body flex will eventually loosen interior panels and contribute to rattling. Not much you can do about it, so why worry?
The engine/transmission will handle just about any abuse you can throw at it, provided the fluid is clean and fresh. These engines have steel timing chains so that shouldn't be a problem either. But when you rev up to 7500 RPM, the engine, gears and differential aren't the only things turning that fast. Engine accessories (ac compressor, alternator, water pump, etc) are revving up too, and the prolonged heat tends to wear them out faster.
That said, drive it and enjoy it, stick to the maintenance schedule, and don't ever let your wife, girlfriend, or teenager drive it.
GW330
02-02-2024 05:41 PM
WolfSongX
Car Care & Detailing
05-10-2017 07:26 PM
maybeg37
09-08-2015 02:33 PM
hollywhip
08-19-2015 09:02 AM
aairi
Buying & Leasing
08-14-2015 02:10 PM
Quick Reply: Is the G37 Sedan meant to be driven hard?
