Can I cancel G37 Sedan Maintenance Plan and get full refund?
Infiniti recommends every 3750 miles a new oil change and uses synthetic oil, i dont know what the difference between the oils are but its just like the gas in the car they recommend you to use 91plus but you can use 89. All that they do is just keep your car running smoother, and if you have the service plan why wouldnt you want to get an oil change every 3750 miles?
Thank you all for your input. My plan is schedule 2 which contains 6 services within my 39 months leasing period. According to the maintenance guide,
1. Every 7.5k or 6 months for oil change + tire rotation
2. 15k or 12 months replace in-cabin microfilter
3. 30k or 24 months replace brake fluid, engine air filter, in-cabin microfilter
4. 45k or 36 months replace in-cabin microfilter
So basically, 6 oil change + tire rotation, 2 in-cabin microfilter replacement, 1 engine air filter replacement, 1 brake fluid replacement.
The plan itself cost me $978, and I called them so I can cancel it and get full refund within 60 days after I lease the car.
Here is the price reference from beshoff infiniti in bay area. Beshoff Infiniti | San Jose, CA - New and Used Infiniti's in San Jose | New & Used Car Dealer
It looks like the plan is cheaper than pay to go. Do you guys have any experience of leasing car and not buying the plan? For oil change + tire rotation, can I just go to some national chain store instead of dealer? The $99 or $79 for oil change is a rip off to me, sorry I used to drive honda accord, and oil change is only about $35.
Thank you
Thank you
If the maintenance plan is anything like the extended warranty, you should be able to cancel it within 30 days, and after that cancel the "unused portion" on a pro-rated basis.
Esther's recommended, but that doesn't mean the dealer's guaranteed to use it. Esther's recommended on my G25 also, just had my "first oil change free" done. They used QuakerState SynBlend without even asking me.
If the maintenance contract specifies Esther and you feel it is important to fill with Esther, your two year contract isn't a bad deal. On the flip side, your overall cost would be a lot less if you used dino or a synthetic blend and went to an independent shop.
Because it's a 3 year lease, I wouldn't pay any extra to use Esther. It's not required by the warranty, so you can save a lot by using dino or synthetic blends, and as long as you change every 3 months you're fine.
Link below for Beshoff Infiniti San Jose's costs, to give you an idea of what the costs are.
i leased, and didnt get any service plans. i dont drive alot, so it made no sense anyway. instead, my dealer has a lifetime oil change program (well, lifetime of the lease) where i get free oil changes, and it costs $200 upfront. are they using synthetic oil with esters? most likely not. do i care? not really - if the dealer puts in dino, then who am i to argue against it.
This is the first time I lease a car, so when lease ends, if they find out engine has some build up or some issue due to not frequently changing oil, are they gonna hold you responsible?
Thx.
$200 for lease life time oil change is pretty good deal... NYC is too far away from here ....
Thx.
Thx.
Thank you
Thank you
if you take your car to a quality independent garage you will come out WAY ahead. and if you do minor items like air and cabin filter DIY you will save even more. these are very simple tasks that require no mechanical aptitude.
Oil change intravals were increased to 10,000 miles on 2011 Highlanders....my 08 Highlander was 5,000 miles. They are using synthetic oil now. I suspect they still want to perform an "inspection" every 5,000 miles.
I spoke to my dealer about this issue...and Infiniti "softened" the recommendation for the 2011 model. My just be a line of BS, but I was told there were some changes made to the 2011 model that make it more acceptable to use regular dino/synthetic oil.
I buy 5 quart Penzoil Ultra Synthetic Oil at Walmart. I then take it to the dealer to have them do the labor. They charge me $15 which includes new washers and disposal fee. I can it do it myself, but for $15 I would rather let someone else get dirty plus I have paperwork that proves I have been servicing my leased G. The Air Filter is the easiest to replace and the cabin filter requires a little more time, but it is easy to do. Save your money and do it yourself. I come from an Acura Integra and yes the G is more expensive to own.
Thank you guys. I guess the first thing I will do once I receive the copy of maintenance agreement is to cancel it and get refund. Where to buy Infiniti filter btw? At dealer? Or any compatible filter is ok?
