2009 G37X Rough Shifting
Old Nov 23, 2010 | 10:22 AM
dirtymaf's Avatar
dirtymaf
I've read several threads on here about the rough shifting on the G37. Since I've gotten mine, I've been experiencing the same issues as others with rough downshifts from 30-20mph, unnecessary hunting, transmission not allowing the car to coast much. I called the dealership because I suspect the TSB hasn't been applied to my car. The service tech was pretty honest about all of it and told me that the TSB addresses the rough down shifting, but that there are other open transmission issues and he's hoping Infiniti will do more updates to address them.
Anyone know if the 2010 and 2011 transmissions are the same as the 2009? My biggest worry is that all that rough handling of the transmission is going to lead to short life and that it will die, of course, right after the end of the warranty.
Old Nov 23, 2010 | 11:22 AM
bocaytomas's Avatar
bocaytomas
I have an 09 x as well, mine does in fact do a downshift around 20 mph but how do you drive the car? I say that because I know that when I drive sporty the car realizes how I'm driving and will start holding shifts for longer and downshift more aggresively. Try reseting the ESU, that may help. Also I asked my dealer about the TSB but said the update that was out there did not apply to mine.
Old Nov 23, 2010 | 11:41 AM
jarena2104's Avatar
jarena2104
lmfao welcome to the world of ****ty transmission's in the X model at least! god knows i got all kinds of problems.
Old Nov 23, 2010 | 11:47 AM
cvroom's Avatar
cvroom
the software updates for the 2010 trans are more up to date than the 2009. mine seemed to get alot better after a couple weeks of driving it. i do notice the flare that has been brought up on here quite a bit. at teh very second the trans shifts from 3rd to 4th its like the trans is anticipating a downshift instead of a upshift and it pumps the rpms with a similar feeling to the revmatching characteristic even though your not giving it more gas. it then upshifts from 3rd to 4th and proceeds to operate normal. its always between the shift in 3rd to 4th. somebody stated that it was the torque converter locking up. could be that or could be software related to the revmatching .
Old Nov 23, 2010 | 02:39 PM
bocaytomas's Avatar
bocaytomas
Yea I heard our cars have "revmatching" but what exactly is it? Is it like when I drive stick you do like a downshift?
Old Nov 23, 2010 | 03:24 PM
cvroom's Avatar
cvroom
down shift rev matching operates during D, DS or manual mode. when the car downshifts it automatically brings up the engine rpms. this reduces wear on the whole drivetrain since the engine rpms are brought up to match the transmission gear. while in ds and d the trans will downshift automatically with revmatching while braking which helps slow the car down using the engine and reduces brake wear. if your 7at has not adapted to your driving habits yet you may feel herky jerky downshifts while braking.
i think if you have automatic transmission on a car without revmatching it probably is not programmed to downshift while braking since day in and day out this would eventually reduce the life of the transmission.
Manny735
Aug 14, 2017 09:25 AM
jfisher
Sep 13, 2015 07:58 AM
inspector94
Sep 8, 2015 12:57 PM
Rodknock
Sep 7, 2015 03:43 PM
Andyg90
Sep 2, 2015 06:10 PM
