Factory Service Manual (FSM) for Sedan
Old Nov 19, 2010 | 02:24 AM
Fezzik's Avatar
Fezzik
Exclamation Factory Service Manual (FSM) for Sedan
Thought I'd share this to the community I paid a membership and got updated NICOs FSM for the G37 and 370z. May want to sticky this.
Factory Service Manual in PDF format.
Index of /FSM/G37
Old May 28, 2016 | 01:25 PM
afar1's Avatar
afar1
In the menu, open "GI", general information, see page 5 in the symbols table for the symbols explanations and the torque units. The numbers in the parentheses are torque specs in metric and non-metric units.
Also, pay attention to the color of the torque symbol, white for ft-lb, black for inch-lb; it's all there.
http://www.nicoclub.com/FSM/G37/Coupe/2013/GI.pdf
Old Sep 6, 2016 | 02:26 AM
Melophile's Avatar
Melophile
All this can be found in the FWD chapter of the factory service manual, but I wanted to write this up for people, like me, who didn't know about the FWD chapter.
I would've hyperlinked everything below, but I didn't want to mix up different years/models so I figured writing out the chapter abbreviations would suffice. I also would've posted this in the Coupe section, but the factory service manual thread over there is locked.
General Information
  • GI - General Information
Engine
  • ACC - Accelerator Control System
  • CO - Engine Cooling System
  • EC - Engine Control System
  • EM - Engine Mechanical
  • EXT - Exterior
  • FL - Fuel System
  • LU - Engine Lubrication System
  • STR - Starting System
Transmission & Driveline
  • CL - Clutch
  • DLN - Driveline
  • FAX - Front Axle
  • RAX - Rear Axle
  • TM - Transaxle & Transmission
Suspension
  • FSU - Front Suspension
  • RSU - Rear Suspension
  • WT - Road Wheels & Tires
Brakes
  • BR - Brake System
  • BRC - Brake Control System
  • PB - Parking Brake System
Steering
  • ST - Steering System
  • STC - Steering Control System
Restraints
  • SB - Seat Belt
  • SBC - Seat Belt Control System
  • SR - SRS Airbag
  • SRC - SRS Airbag Control System
Ventilation, Heater & Air Conditioner
  • HA - Heater & Air Conditioning System
  • HAC - Heater & Air Conditioning Control System
  • VTL - Ventilation System
Body Interior
  • ADP - Automatic Drive Positioner
  • INT - Interior
  • IP - Instrument Panel
  • SE - Seat
Body Exterior, Doors, Roof & Vehicle Security
  • BRM - Body Repair
  • DLK - Door & Lock
  • EXT - Exterior
  • GW - Glass & Window System
  • PWC - Power Window Control System
  • RF - Roof
  • SEC - Security Control System
Driver Controls
  • DEF - Defogger
  • EXL - Exterior Lighting System
  • HRN - Horn
  • INL - Interior Lighting System
  • MIR - Mirrors
  • WW - Wiper & Washer
Electrical & Power Control
  • BCS - Body Control System
  • CHG - Charging System
  • LAN - LAN System
  • PCS - Power Control System
  • PG - Power Supply, Ground, & Circuit Elements
  • PWO - Power Outlet
Driver Information & Multimedia
  • AV - Audio, Visual & Navigation System
  • MWI - Meter, Warning Lamp & Indicator
  • SN - Sonar System
  • WCS - Warning Chime System
Cruise Control & Driver Assistance
  • CCS - Cruise Control System
Maintenance
  • MA - Maintenance
Old Mar 18, 2019 | 10:46 PM
Thanks to jaydee23 for finding this link to the Q40 FSM.
https://1drv.ms/b/s!AoPSgypo2YBwrXSD4aUU8gsv_a6q
Old Dec 9, 2019 | 06:34 PM
DavidO's Avatar
DavidO
Thank you for this information! I'm in a "clutch linkage failure" mode, and this resource is valuable as heck!
Old Nov 6, 2023 | 10:03 AM
EhrenTheMan's Avatar
EhrenTheMan
It appears that NICO club no longer has the FSM's for G's anymore but I got a copy that I have on a google drive. Link: https://drive.google.com/file/d/13p_...ew?usp=sharing
Old Feb 3, 2024 | 07:38 PM
iLLuZioNz's Avatar
iLLuZioNz
You’re a legend, thank you so much!
Old Mar 13, 2024 | 09:23 AM
EhrenTheMan
anytime
Old May 31, 2024 | 07:41 PM
jaydee23's Avatar
jaydee23
https://charm.li/
This is quite amazing!
superjoey
31
Mar 22, 2023 11:56 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
BANNISTER
Dec 10, 2015 04:14 PM
em1990
Aug 11, 2015 01:22 PM
