2010 G37 sedan Fogs
Old Sep 29, 2010 | 12:43 PM
leeI35G35's Avatar
leeI35G35
Originally Posted by DocJohn
How did you wire your fog lights to be powered independent of the headlights and parking lights?
+1 x Infinity
Did you have to buy the KT Kit or did you do some wire splicing?
Old Sep 29, 2010 | 01:43 PM
BLKG37X's Avatar
BLKG37X
Originally Posted by sniper27
for any car, if you already have HIDs, you can swap just the bulb for a different color temperature, or if you need a replacement. If you don't have HIDs, then you need a kit with the ballasts, wiring, and HID bulbs.
I see. Sorry to take this a bit off topic.....
My gf just leased a 2010 Sentra, and the headlights are really crappy and offer very little light. I want to improve them.
Those are regular headlights and not HIDs, and I want the light to be brighter for better visibility. Should I just swap out the bulbs for a "hyper white" set, or go all the way with the kit? Would there be a huge difference in terms of brightness between the hyper whites and the hid kit? And very important, will the HID kit void her warranty?
Again, sorry for being off topic.
Old Sep 29, 2010 | 02:29 PM
DocJohn's Avatar
DocJohn
G-DOG
A good quality HID kit is going to be far superior in terms of light output (brightness) than even the best halogen bulbs.
As far a voiding the warranty is concerned, under the Magnuson-Moss Warranty Act the dealership could deny a claim for repairs covered under the vehicle’s warranty only if they could prove that your mod directly caused the problem that you are requesting repairs for.
Old Sep 29, 2010 | 02:34 PM
sniper27's Avatar
sniper27
in this case, i would say yes, if you have problems with your headlights, they will not warranty your aftermarket HIDs. but as far as light output, all those so called "hyper white" or "plasma" or "xenon" filled halogen bulbs are all crap. those will actually give you less light compared to your stocks.
Old Sep 30, 2010 | 02:21 AM
maxfinity's Avatar
maxfinity
Originally Posted by leeI35G35
+1 x Infinity
What kit are you talking about?
Old Sep 30, 2010 | 08:04 AM
xorca80x's Avatar
xorca80x
size for the fog light is h8 correct?
Old Sep 30, 2010 | 09:09 AM
DocJohn's Avatar
DocJohn
G-DOG
Yes, H8 is the correct bulb for the fogs.
Old Sep 30, 2010 | 09:14 AM
DocJohn's Avatar
DocJohn
G-DOG
KP Technologies makes a control module for independent fogs.
KP Technologies
It would probably work in the G37 too if you could figure out the correct wiring.
Old Sep 30, 2010 | 09:24 AM
ScottyBeGood's Avatar
ScottyBeGood
KP Technologies
Do you have a DIY on this?
Old Sep 30, 2010 | 09:47 AM
DocJohn's Avatar
DocJohn
G-DOG
No, I never installed one of these myself, but I have seen them installed and working on some earlier G35's.
Old Sep 30, 2010 | 04:29 PM
xorca80x's Avatar
xorca80x
thanks for the reply Docjohn...got another noob question.
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
does this kit come with everything i need to hook up? do i need to pick up the hid harness, error eliminator, or adapter cables?
thanks
Old Sep 30, 2010 | 06:55 PM
leeI35G35's Avatar
leeI35G35
KP Technologies
Thanks..I meant to say KP not KT. Anyway, if you go to the KP website and select 2010-> Infiniti -> G37 Sedan...it shows a foglight module kit ITEM#MX20 for $49.00. I may purchase that kit.
Side note: I went to a thread where "use2vw" stated he bought a relay module for $25 to control his fogs. I would like to see if he chimes in on where he bought his module from.
Old Sep 30, 2010 | 10:40 PM
use2vw's Avatar
use2vw
Yeah my set up shines yellow output, but from head on the light is more white...(better in my opinion cause attracts less wrong attention)...ALSO, I knew that the KP switch is out there, but I just went with a separate switch and relay to have total independant control of my fogs. $24 + 30mins install and wah-lah....good enough for me since I gotz to return her in 33 mos.
Old Sep 30, 2010 | 11:48 PM
  #29
terfer's Avatar
terfer
I'd def go with a 35w kit. 55w is pretty high for such a small fog housing. 3k or 6k is the way to go!
Thedbarz
33
Feb 9, 2016 12:05 AM
maybeg37
Sep 8, 2015 02:33 PM
connoisseurr
Sep 2, 2015 09:18 PM
pcwd
Aug 12, 2015 06:54 PM
asato3
Aug 7, 2015 08:45 AM
