10 g37s sedan question
Old Jun 30, 2010 | 02:44 PM
GmOnEy1's Avatar
GmOnEy1
lookin to get rims 19x9 front 35 offset with 245 45 tire n rear 19x10 35 offset with 275 40 tire with a eibach pro drop will the offsets work without rubbin or should I get a 40 offset rear or drop to a 19x9.5 with 35 offset n should I try to get as close to zero camber thanks
Old Jun 30, 2010 | 02:48 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I think those first numbers you listed are fine but I would drop the front tires to 245/40 instead of 245/45
But you should be fine on Eibachs and +35 all around
Old Jun 30, 2010 | 03:02 PM
GmOnEy1's Avatar
GmOnEy1
I know the smaller tire would be better but I'm in ny would the 45 fit it shouldn't be a prob cause the coupe comes with 19 with the 45 in front
Old Jun 30, 2010 | 03:13 PM
hispeed-lowdrag
Yeah you should be fine with either, all the original numbers you listed should work out just fine
Old Jul 1, 2010 | 11:17 AM
GmOnEy1's Avatar
GmOnEy1
Should I do the drop first or wheels
Old Jul 1, 2010 | 11:24 AM
hispeed-lowdrag
personally...I'd go with a drop...but if you are just looking to get springs (and not coilover) then a drop only costs $200-250. So you could do both at the same time.
If you are doing coilovers, obv those are a little more but still not too bad
Old Jul 1, 2010 | 11:57 AM
da mayor's Avatar
da mayor
i have a 3" drop and i fit 20x10" fronts with a stretched 245/30/20 tire and 40mm offset
no camber adjustments or kit on
I dont have the Akebonos... just find wheels that clear the BBK's
Old Jul 1, 2010 | 01:22 PM
GmOnEy1's Avatar
GmOnEy1
I know the fronts will fit no prob with a 35 offset but I heard with the rear with the 19x10 I mite run into a rubbin issue so I was either gonna go with the 10 with a 40 offset or a 9.5 with a 35 offset I just want the 275 40 tire in the rear n the 245 45 front. I just don't understand the camber so will it be best to try n get back to almost zero or to -1
G's
Nov 5, 2023 12:01 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
cellwoot
Aug 13, 2015 04:27 PM
