(Pic request)Trunk spoiler on blue slate sedan?
Old May 13, 2010 | 10:48 AM
antirice's Avatar
antirice
Old May 13, 2010 | 11:25 AM
mindonmatter's Avatar
mindonmatter
Originally Posted by Frshnsokln
Where did you order the trunk lip spoiler from?
Riverside Infiniti. 400 shipped.
Old May 13, 2010 | 11:29 AM
Alex57r's Avatar
Alex57r
I am with mindovermatter. I don't like that one AT ALL!!! I want the factory lip but at $400 + install, not going to happen.
Antirice --> LMAO!!!
Old May 13, 2010 | 06:53 PM
mindonmatter
Just got home from work and my spoiler was waiting on the front porch. Hope to install it tomorrow and will post pics then.
Old May 13, 2010 | 10:52 PM
urirx98's Avatar
urirx98
1st off it does come painted for 110, this is my 2nd time buying from them, and like u said, to each his own. This is called the Euro spoiler, and to myself, looks much better then the stock OEM, which looks awesome if the car was a 2 door, but again doesnt get rid of your least favorite part, the chrome. I actually like the chrome, and this way keeps the look nice and clean and gives you a spoiler to boot!
Old May 14, 2010 | 04:13 PM
mindonmatter
urirx98,
Sorry, I didn't realize it came painted. That is a good price. As long as you're happy with it, that's all that matters.
Old May 14, 2010 | 04:17 PM
mindonmatter
Just installed it. Here's a quick pic from my phone. It really doesn't look very good in my pic, or others I've seen. It looks much better in person.
It turned out to be a little more of a PITA to install than I thought it would be. Better directions would make it easier. It's a DIY that most people should be able to perform though. On to the next one.
Old May 14, 2010 | 05:18 PM
B L U E S L A T E's Avatar
B L U E S L A T E
This is my 07... with Tommy Kaira trunk spoiler.
Old May 14, 2010 | 05:49 PM
15951's Avatar
15951
That looks great. Can you discuss the install a bit more? It would be really great if you could post the directions so we can get an idea of what it takes to install.
How is the color match?
Old May 15, 2010 | 12:23 AM
urirx98's Avatar
urirx98
After the spoiler, the next will be to take off the INFINITI again and tint it up. That spoiler looks good, but I still prefer the Euro over it cause i like the Chrome under it. Good luck
Old May 15, 2010 | 09:47 AM
mindonmatter
The color match is perfect. I already threw away the directions, but I'll give a quick rundown of what's required:
The trunk lid liner must be removed. Easy.
Unplug camera and trunk button wiring. Push grommets through.
Remove 4 nuts holding the chrome strip on.
Pop the chrome strip off(two clips still holding it there).
Remove the bracket from the chrome strip that is holding the backup camera and trunk button.
Remove the backup cam and trunk button from bracket.
Transfer both to the new bracket.
Attach new bracket to the new spoiler.
Put the 5 templates in their respective places. Center punch drill locations.
(Just a note about the templates. They are perfectly sized and cut. It is very easy to align these templates to get an the exact location to drill holes)
Drill out the 5 holes. After center punching, drill each hole using a 1/8" bit. Then open up the holes using a 5/16" bit. Debur holes. Apply rust preventative to edges of holes(I just used touch up paint).
Clean the area that will get double stick tape with alcohol/water.
Install spoiler using two plastic clips.
Align it properly and remove the two sided tape.
Install the 4 bolts that attach to the spoiler from inside the trunk lid.
Put the trunk lid liner back in. Your done.
Just take your time and double check everything. Mine came out great, perfectly aligned, no gaps.
Old May 15, 2010 | 05:34 PM
15951's Avatar
15951
Perfect - thanks for taking the time to post this. If the templates are actually done well, that makes all the difference.
Old May 16, 2010 | 05:06 PM
marty315's Avatar
marty315
Sorry for the slight hijack but can you post the link to where you got this spoiler and also where you purchased the roof spoiler as well? Thanks!
Old May 17, 2010 | 04:54 PM
  #29
B L U E S L A T E
Roof spoiler: BlackTop Aero Roof Spoiler For 07+ G35 Sedan (ABS) - Ravspeconline.com
Trunk spoiler: japanparts.com : PARTS DATABASE
Old May 18, 2010 | 06:24 PM
  #30
MOB's Avatar
MOB
Are the roof/rear window specs on the 07+ G35 sedans the same as the G37 sedans? Curious about a roof spoiler as well but don't want to order it unless I know FOR SURE the fitment is correct for the 37. Any 37 sedan owners have one with pics to share?
BTW---nice work on the DIY trunk spoiler install. Looks good!
