I finally did it
Old Apr 10, 2010 | 05:15 PM
HoustonG37's Avatar
HoustonG37
I finally did it
Well, I finally had new rims and tires put on. Pleased with the rims (TSW Snetterton 19"), but not with the tires (Goodyear Eagle GT - had A LOT of vibration even after balancing 3 times!). Having the tires replaced with Michelin Pilot Sport AS Plus next weekend. I'll let everyone know how they ride. Please let me know what you think....
Attached Thumbnails I finally did it-100_4161.jpg   I finally did it-100_4160.jpg   I finally did it-100_4162.jpg   I finally did it-100_4163.jpg   I finally did it-100_4164.jpg
Old Apr 10, 2010 | 05:25 PM
soolman32's Avatar
soolman32
Looking gd! congrats on the new wheels.
Old Apr 10, 2010 | 05:38 PM
whiddles's Avatar
whiddles
needs a drop
Old Apr 10, 2010 | 05:46 PM
Sunny G's Avatar
Sunny G
I like the mesh style now to set the wheels off drop your car.
Old Apr 10, 2010 | 06:07 PM
beerme986's Avatar
beerme986
looks the the tires are put on backwards. those grooves should be going the other way so water can escape out of the tread
Old Apr 10, 2010 | 06:18 PM
HoustonG37's Avatar
HoustonG37
Would that cause the car to vibrate?? I'm not that knowledgeable about such things.
Old Apr 10, 2010 | 06:21 PM
beerme986's Avatar
beerme986
im not 100% sure if the tread is backwards, just looks it to me. but i dont think that would cause the car to vibrate, that would be the balance of the tire. if you had the tire balanced 3 times(assuming the shop is good), and still vibrates then it would have to be the rim itself. (no offense but tsw arent the best of wheels)
i would take it to the shop who put them on and have them figure it out.
Old Apr 10, 2010 | 06:23 PM
HoustonG37's Avatar
HoustonG37
Thanks beerme986. That's good to know. I may have to follow up on that suggestion if the change in tires doesn't help.
Old Apr 10, 2010 | 06:35 PM
I think they are asymmetrical and not directional. It looks like your passenger side front is mounted backward on the wheel. I cant see the rears well enough to tell.
Take a look closely at the sidewall. All of them should have a marking that says "OUTSIDE" somewhere on the sidewall if they are asymmetrical. If any of them have the marking that says "INSIDE" on the outside wall, it's mounted on the wheel backward and needs to be reversed. Check it out.
Old Apr 10, 2010 | 06:41 PM
HoustonG37's Avatar
HoustonG37
Thanks Black Betty. I immediately went and checked and all 4 wheels have "Side Facing Outwards" on the outside.
Old Apr 10, 2010 | 07:47 PM
Well you've ruled that out.
Old Apr 10, 2010 | 11:04 PM
FourT2's Avatar
FourT2
Good looking wheels. Just curious, what do you use to clean the tires? I like this look - not tacky but clean looking.
Old Apr 12, 2010 | 10:30 AM
qb37Xs's Avatar
qb37Xs
Wheels looks nice, please post the rim and tire specs when you get a chance.
Old Apr 12, 2010 | 10:36 AM
da mayor's Avatar
da mayor
very simple
Old Apr 12, 2010 | 12:52 PM
tyduong's Avatar
tyduong
Is that a UH license plate? GO COOGS!
