7AT dipstick location?
Old Feb 28, 2010 | 05:26 PM
TinsleyC's Avatar
TinsleyC
I've searched here for 'transmission fluid dipstick" and can't come up with anything.
I've looked under the hood and can't find a tranny dipstick anywhere. The manual recommends leaving service to the dealership, but there is a recommended tranny fluid...
Is there a transmission dipstick anywhere under the hood?
Thanks
Old Feb 28, 2010 | 06:19 PM
SindhiStyle's Avatar
SindhiStyle
someone on G35 driver said this:
"If you are looking at the engine from head on look to the back left of the plenum. It is tucked in that corner just to the right of the battery "casing". It requires i believe a 10 or 15 mm socket to take the bolt off that holds the dipstick in place."
I have not gone outside to check...but hopefully that helps!
Old Feb 28, 2010 | 09:21 PM
TinsleyC's Avatar
TinsleyC
Thanks! I guess they intended this to be a dealer serviceable item.
I'll have to have a look in the daylight...
Old Mar 1, 2010 | 10:26 AM
SkyMG37x's Avatar
SkyMG37x
The 7AT has no dipstick as it is a sealed unit that should only be serviced by the dealer. The previous 5AT has a dipstick below the passenger side firewall.
Old Mar 1, 2010 | 10:00 PM
pulsar's Avatar
pulsar
7AT dipstick
I was wonder about this too. Asked my salesman when he was walking me thru the car and he just gave me a funny look like why would I be doing tranny service. The dealer has to have some means of checking the level? Never before had a car that I could not check, fill and drain the AT fluid myself. Don't like dealers doing anything to my car unless its a warranty item.
Old Mar 1, 2010 | 11:09 PM
Canadian144's Avatar
Canadian144
Just "THINK WITH YER DIPSTICK"
Old Mar 1, 2010 | 11:39 PM
ozzypriest's Avatar
ozzypriest
A lot of newer cars have sealed trannys - My G8 had a sealed / non-user-serviceable tranny.
Old Mar 2, 2010 | 10:00 AM
SkyMG37x's Avatar
SkyMG37x
If you look at the maintenance schedule the 7AT has no service interval defined. The dealer is the only one that should be servicing it.
misc
29
May 24, 2023 03:57 PM
Kojack
Oct 9, 2015 05:53 PM
SON415
Sep 28, 2015 05:49 AM
Allboutcali
Sep 26, 2015 03:43 PM
