Deodarizing Factry Carpet mats
Hi All, Just got an 09 G37XS, love the handling and comfort
Recently to clean some dirt from rain and mud, i used Oxy cleaner on the drivers side mat . The mat now has a striong smell from the OXy cleaner and I donno how to get rid of it
Can you guys recommend a good carpet/mat cleaner that will also deodarize and get rid of the OXy odor
Thanks
Thanks
fabreeze! and roll down the windows.
Thanks
Thanks
For problematic mats with stain, odor & other undesireables, I would use a power washer (just adjust it to a much lower setting). You would be surprised what comes out of these carpets. Just don't do this often to carpets as it may wear down the fabric under such pressures. This is only recommended if you have a "problem mat" but did not want to replace such. A friend had some carpet problems as he had a pet dog sitting on it frequently. We did this, but I mixed some clear colorless anti-septic Chlorhexidine soap solution. (Dont'e used colored betadine antiseptic, they stain heavily). Made it spanking brand new & nearly sterile carpet afterwards.
In a way, it's not what you merely apply to the "problem mat" but what you apply and remove from it. Deodorizing by masking alone may give you relapse odors. Pure deodorizing would entail some tranference of the odor-causing chemical to some other media (washed to rinse water/transferred to cloth or paper, or heated & made to rapidly evaporate).
Try this also if you don't have a power washer... get a steam cleaner (one you use for dress & cloth). Though for hygiene purposes, I would not use this for biologic odors since you risk contaminating the steam apparatus, especially if you want to still use you steam cleaner for other household purposes.
Hope this helps.
Hope this helps.
drizzy315
Sep 14, 2015 08:14 AM
johnadlertech
Sep 11, 2015 02:07 PM
