Will motegi traklite 3.0 clear big brakes
Im looking to buy 18x8.5 +35 offset motegi traklites. does anyone know if these clear big brakes on the sport coupe? i dont want to wait 2 months for them to not fit.
Put your car info in the top right and it says it won't fit. https://www.motegiwheels.com/motegi-..._o_gr60-GM3KRn
I’d recommend a 9.5 width in that offset (or a little lower offset). Go square and you can save $$$ on tires cross rotating them too, just my 2 cents.
Edit - If your car is lowered, go with a +25 to +30 offset if you go 9.5” and that will be close to flush, all around. If on stock suspension, +35 might be better but I wouldn’t go higher offset than that personally. My old Work 9.5 +23 fronts only had a few MM of clearance on the BBK but it varies by wheel. Our BBKs work great with concave wheels though.
