g37 stalled out while driving and now wont crank
Old Jun 29, 2023 | 05:14 AM
mattsmth's Avatar
mattsmth
so i was driving my 08 g37 manual as i was making a turn the car/ dash kinda freaked out a little bit then it stalled i rolled into a parking lot and went to try to restart it and it would not crank not even try to. i push in the clutch and and press the start button and the car will just keep going LOCK>ACC>ON and it will just keep running thru it over it happened in the rain and i lost my front left wheel liner so is there something that could’ve gotten wet? maybe the clutch sensor went bad if so is there a way to check it but why would it stall out hopefully someone can lead me in the right direction
Old Jun 29, 2023 | 10:07 PM
beefychicken's Avatar
beefychicken
Search in the forum for sunroof and/or cowl leak. This sounds like your issue. Essentially what happpens is water gets into the car on the passenger side and soaks down the BCM which can result in issues like you mentioned.
jetson
Dec 22, 2025 10:24 AM
silentnovocain
Aug 25, 2018 12:56 PM
brad126
17
Jun 12, 2013 08:03 AM
SRG
19
Feb 15, 2012 05:43 PM
myk1013
Apr 30, 2011 05:43 PM
