2012 g37 coupe Unknown overheating
Old Apr 11, 2023 | 01:21 PM
Lim305's Avatar
Lim305
Hey everyone,
so last year around October or November my car started to randomly overheat if I stay still or drive at a low speed (10-40 MPH). When I went to check to see if my fans turned on they never did although, when I ran the IPDM test they turn on Low & High. I’ve changed the ECT, control module, gutted the thermostat, Changed water pump, burped the system, & wired the fans to run full blast through switch but she’s still overheating.
A couple days ago I ordered a CSF performance radiator & I’m going to get some new fans just in case because this really doesn’t make sense. my question is… has anyone had this problem before ? How did you solve it ?
(I hope this doesn’t matter but I also did a VR30 trans swap with a trans oil cooler)
Old Apr 11, 2023 | 07:04 PM
thescreensavers's Avatar
thescreensavers
Do you have an IR Gun? Can you confirm you are actually overheating? Could be a bad temp sensor.
If you run the AC Max cold when moving slowly does it still overheat? Fans should be on.
Old Apr 12, 2023 | 09:53 PM
Lim305's Avatar
Lim305
No i don’t have an IR Gun. I know that it’s overheating because I had to change my bleeder screw due to it being too hot and it snapped in half. I already changed the ECT maybe I should get an OEM sensor ?
Yes, even if I blast my A/C it’s blows hot air on 60 while I move slowly and starts to overheat. When I start driving a constant 60 MPH or over it blows super cold and ECT stays between 183 & 187 Degrees Fahrenheit. I wired my fans to blow full blast to eliminate the fans from being the culprit.
Old Apr 13, 2023 | 09:24 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Did you check that the radiator and condenser fins are not clogged? Over time, dirt, bugs, road debris can accumulate and clog the fins which can hinder air flow/ heat rejection.
Old May 4, 2023 | 06:26 PM
CesarR70's Avatar
CesarR70
I had a similar issue with an old impala, I replaced the thermostat and thought I burped the coolant system.
Turned out there were still a ton of air pockets inside.
I ended up burping it again by starting with a cold engine and using a spill proof funnel.
Open the windows, get out of the car and crank the heat to max, let the car idle until the heat inside the cabin is as hot as possible. Even if the coolant gauge reads operating temp, keep the car idling with your funnel full of coolant.
Dont bother opening any of the bleed screws, just keep topping off with OEM blue coolant.
ZoeInfiniti
May 17, 2021 11:18 PM
BAL42
Feb 10, 2021 05:13 PM
MAK789
14
Jun 7, 2020 02:51 PM
Spadds76
Sep 22, 2019 05:34 PM
armino41
Feb 15, 2017 09:15 AM
