2008 G37 Sport : A/C Compressor Replacement
Old Mar 29, 2023 | 11:37 AM
pshirk's Avatar
pshirk
My A/C compressor has failed on my 2008 G37 Sport (manual) and I am needing to replace it. To my knowledge, it’s important to replace the condenser as well otherwise you risk the new compressor prematurely failing. I was looking for some education / recommendations on what to purchase. I’m not looking for top shelf but rather just something to do the job as I’m likely going to sell sometime soon.
1) For compressor, I was looking at the Four Seasons 68674 w/ DCS17EC compressor w/ clutch, OE specified Oil from RockAuto. Will this fit with my vehicle? It appears it will according to their website but I wasn’t 100% sure.
2) From what I understand about this particular vehicle, the A/C condenser and radiator come as a single assembly. So essentially it seems that I’m replacing both the condenser and radiator. Is this correct?
3) assuming the above is correct, I was looking at purchasing a Nissan Radiator and AC condenser assembly (part #: 21410-JK20B) through z1 motor sports. This appears to be the most cost effective. Are there any other recommendations or knowledge on whether this part will fit my vehicle?
Any feedback is greatly appreciated!
Old Mar 30, 2023 | 11:08 AM
projectpanda13's Avatar
projectpanda13
2.) you are correct, its a sinlge unit together from factory.
3.) part number semms correct. it will fit. I bought a CSF unit when i had to replace mine
Old Mar 30, 2023 | 12:21 PM
pshirk's Avatar
pshirk
Awesome thank you. To your knowledge, will the compressor model I detailed work for my vehicle as well?
Old Mar 30, 2023 | 12:28 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Out of my own curiosity, how did the compressor actually fail?
Old Mar 30, 2023 | 12:34 PM
pshirk's Avatar
pshirk
Not entirely sure. I had cool air at one point and over the course of 10 minutes there was no cooling whatsoever. Low pressure coolant line was at zero psi. Tried to add Freon but it wouldn't hold any kind of pressure. Took it to a shop and they brought me out to look once they had it opened up. Compressor oil was all over the ground. I initially thought it was antifreeze (neon green color) but it was a much thicker consistency which I would've expected from oil.
Old Mar 30, 2023 | 01:11 PM
ILM-NC G37S
If the compressor had seized or shattered internally, you would know it. Based on your explanation, it seems more likely that one of the AC lines broke. While moderately rare, there have been cases where the high-side fitting broke/ came loose on some of these cars. You may want to check this thread. Also, the refrigerant oil has a UV dye added which aids in locating leaks when under a "black light" which is the neon green color you saw.
I doubt seriously you need to replace the compressor AND the condenser/radiator assembly.
Old Apr 18, 2023 | 03:46 AM
mocarob's Avatar
mocarob
What is "CSF unit' ? How do I know if this same part# will fit a 2010 Coupe?
Thanks
Old Apr 18, 2023 | 09:00 AM
pshirk's Avatar
pshirk
Thanks
I purchased the CSF unit from Z1 Motorsports. https://www.z1motorsports.com/radiat...SABEgKSw_D_BwE
I reached out to Z1 prior to purchasing to verify that it would fit my vehicle. They said it would but upon getting it, I realized that was NOT the case. The mechanic I asked to install the part said there was no way the upper radiator hose would go on without butchering the fan shroud. Now I'm having to go through the painstaking process of trying to get my money back from Z1. Extremely frustrating.
Old Apr 18, 2023 | 10:12 AM
socketz67's Avatar
socketz67
Community Builder
Interesting. In all the years I have been a member of the community, I have seen few AC compressor failures. I guess as these cars are getting up their in age (10-14 years), it should be expected. If you can. take of pic of the parts you purchase and report back on the replacement process as I expect others in the future may be able to leverage.
Old Apr 18, 2023 | 11:17 AM
ILM-NC G37S
Compressor failures are relatively rare these days compared to the units of the 60's-80's. It is more likely for the seals or piping to fail than for the unit itself. In few cases, whenever a compressor seizes or shatters, it is usually due to either some hidden defect in the manufacturing process or excessive refrigerant pressures .
Now, in the old days, compressor failures were a lot more common mainly due to inactivity. AC-Delco (GM) was the worst as their belt pulley bearings were notorious for seizing. Back then, for many, the AC was barely used, if at all and almost never during the winter months. This resulted in the compressor sitting idle for extended periods of time. The rule of thumb was to run the compressor at least 5 minutes a month EVEN in the winter months. This allowed the refrigerant oil to circulate throughout the system to keep the seals, bearings, pistons, rotors, vanes, etc. lubricated. Of course if you had GM, well, pray.
Nowadays, with automatic AC systems, the compressor is usually engaged more so than it is not. This extends the health of the system greatly. As long as the condenser is kept clear and clean, failure rates are kept low. For these cars, the main "weak spot" in the system is Nissan's "one touch joint" connection that have a (small) history of failures, usually on the high-side of the system. This is what I suspect was the OP's original issue.
Old Apr 18, 2023 | 02:27 PM
mocarob's Avatar
mocarob
If this CSF unit didn't fit properly, What brand unit did you end up getting? This guy documents his issues installing a CSF.
Old Apr 18, 2023 | 11:41 PM
mocarob's Avatar
mocarob
After a closer listen, That video is about a CSF Triple Pass. Part # 7012T not the 3721..
Old Apr 19, 2023 | 09:04 AM
pshirk's Avatar
pshirk
The 7012T is what they ended up sending me (which didn't fit). Are you saying the 3721 is the one I should've gotten instead?
Old Apr 19, 2023 | 09:23 AM
pshirk's Avatar
pshirk
Parts used for the replacement
  • Four Seasons 68674 w/ DCS17EC compressor w/ clutch - $233 (https://www.rockauto.com/en/moreinfo...t=6628&jsn=831)
  • Genuine Nissan Advantage Line Radiator/Condenser unit ~$640 (mechanic sourced this; likely includes markup)
    • Supposedly a more cost effective route than the standard unit you purchase from Nissan which is around $860. This route was only taken after the CSF unit did NOT fit
Total Damage: ~$2000 if I can manage to get a refund from Z1, ~$2600 if I can't.
  • ~$700 in labor
  • ~$90 in Freon
  • Shop originally quoted me ~$2800 to source parts and do install
Old Apr 19, 2023 | 10:17 AM
socketz67's Avatar
socketz67
Community Builder
Thanks for sharing pshirk. Seems to make sense that the recommendation is to replace the compressor and condenser in tandem. Since the radiator was also replaced, it sounds like you ended up with a new HVAC & refurbished cooling system for roughly 2K, which seems reasonable as I imagine there was a fair amount of labor involved (not sure what the book is on the job, but this could realistically take a full day I'm sure).
Excellent post above ILM-NC G37S. It sounds like you are in the industry? I have owned several cars from the 70-90s that had the AC system go south and the car lost a large percentage of its value as a result because a replacement was over a thousand dollars many years ago. I recall my old man telling me to run the AC in the winter because it will last longer...
