Rattle noise that can be only heard inside of car
Old Mar 1, 2022 | 04:08 AM
Mchavez's Avatar
Mchavez
Hey what’s up guys I have a 2014 q60 coupe and I have this rattle noise that seems like it’s coming from the engine but could be from down under or near the dashboard. From the outside you really can’t hear it or standing in front/near the engine but only mainly inside the car. Then when I press the pedal and rev it, it goes away instantly. Not sure if anybody has encountered this before if it’s a heat shield or something loose rattling. I took a short video of it with my phone on top of the dashboard from the inside to show how it sounds.
Old Mar 3, 2022 | 10:21 PM
beefychicken's Avatar
beefychicken
Does it sound as if it's originating on the passenger side? I only ask because I have a similar rattle from the passenger side dash but have not taken the time to investigate.
Old Mar 3, 2022 | 11:21 PM
Mchavez's Avatar
Mchavez
Yes it does!!! My girlfriend noticed it more today and she says it sound as if it’s right under where she puts her feet at so I’m thinking possibly a heat shield or the cat that’s under there. I’m clueless tho because it only does it here and there and when I give it gas it goes completely away.
Old Mar 4, 2022 | 06:09 PM
dwb993's Avatar
dwb993
I had a similar rattle in my 2013 coupe. I happened to be under the hood doing something else when I moved the AC check valve and heard it make the same noise! Its on the passenger side of the engine and I have attached a picture. Use some kind of tiedown to keep it from moving around freely. IIRC, I did not have to tie it down to anything overly securely -- just stop it from swinging around freely. Problem solved.
Old Mar 4, 2022 | 06:41 PM
beefychicken
Looks like u/dwb993 may have figured it out! I'm gonna go look in few. Seems to make sense.
BTW, I know it's not the cat heat heat shield as I have HFCs mated to a CBE so there are no heat shields in my exhaust system other than what's on the OE headers.
Old Mar 4, 2022 | 06:51 PM
Mchavez's Avatar
Mchavez
Yeah I’m checking that out later forsure. I just didn’t want to rule out anything that can be loose underneath but I haven’t looked underneath either. But I’m hoping that’ll be the fix.
Old Mar 4, 2022 | 10:22 PM
Mchavez's Avatar
Mchavez
So I tied down that AC check valve thing and didn’t make a difference. I’m honestly thinking it might be the headers heat shield or hoping for it to be something just loose since it sounds like it’s more plastic then metal rattling.
Old Mar 5, 2022 | 10:20 PM
mike81's Avatar
mike81
I have the exact same problem whenever we stop at a light or in the driveway warming up there’s this metal sounds like a loose bolt or something coming from the passenger side then goes away when I drive. Doesn’t seem like anybody has figured it out yet
Old Mar 5, 2022 | 10:35 PM
Mchavez's Avatar
Mchavez
im guessing we might just have to live with it but hopefully someone finds the fix for it. THANKS FOR ALL THE INPUT GUYS I APPRECIATE IT.
Old Mar 6, 2022 | 12:14 AM
spoolin03's Avatar
spoolin03
Could also be an exhaust piece rattling against something. I would put the car on jack stands (safely) and fire it up and get under it and have someone rev it a little.
Old Mar 6, 2022 | 12:15 AM
spoolin03's Avatar
spoolin03
or take to an exhaust shop to have them inspect it for you
Old Mar 6, 2022 | 12:22 AM
Mchavez's Avatar
Mchavez
Ill give it a shot my self after this snow in Colorado this weekend. I’ll raise it up and have someone rev it
Old Mar 6, 2022 | 02:09 AM
14Q60awdSPORT's Avatar
14Q60awdSPORT
that is not the AC check valve.
that is the evap vapor valve service port.
Just wanted to clarify.
Old Mar 7, 2022 | 05:08 AM
Stuart Pid's Avatar
Stuart Pid
Thumbs up
Found the mysterious rattle in my 2015 Q60, it was the windshield wiper fluid neck and bottle. It was loose from the mounting point. Rattle was more noticable in cold weather.
Old Mar 7, 2022 | 09:53 AM
Mchavez's Avatar
Mchavez
I’ll look into that as well man, thanks!
