Pop sound from window, now doesn't work
Old Dec 12, 2021 | 10:36 AM
Crunk's Avatar
Crunk
This morning there was a lot of Frost and it was pretty cold. I was able to get into the car as it did roll down the quarter inch or so needed to open. But I noticed when I got to the gas station that the window is still partially down. Once I was done pumping I turned the engine on tried to roll the window up with the button and it made a loud pop sound. The window went down a little bit, from gravity not with the motor. It made kind of a grinding sound if it tried to motor up so I went ahead and stopped trying to use the button.
I've got the convertible, but I think it's the same window and all that is the coupe.
Any ideas? I'm guessing I'll have to take this somewhere to get fixed. My window had some deep scratches along the outside anyway, like maybe the pads that hold the window on were worn down and it was letting it touch metal, or maybe some rocks have been trapped. I checked for a little rocks and whatnot a long time ago I never found any.
Old Dec 12, 2021 | 11:23 AM
Ponyryd's Avatar
Ponyryd
Most likely broke the window regulator, it’s a cable mechanism.
Old Dec 12, 2021 | 01:22 PM
Crunk's Avatar
Crunk
Is it an easy fix? I could have time Tuesday but it'll be cold out
Old Dec 12, 2021 | 11:40 PM
Crunk's Avatar
Crunk
Could you help me find the right part? A guy at a body shop offered to help if I can get the part. It's the driver's side of a 2012.
Old Dec 19, 2021 | 05:11 PM
beefychicken's Avatar
beefychicken
Genuine OEM Infiniti Parts and Accessories Online - Infiniti Parts Deal
Old Dec 19, 2021 | 05:57 PM
Crunk's Avatar
Crunk
Fixed the cable, thanks y'all
Matty_baby
Picture Share G Coupe
21
Feb 6, 2019 03:09 AM
Bossman
Aug 17, 2017 04:45 AM
blam
May 26, 2012 06:24 PM
redG37s
Mar 21, 2009 03:55 PM
