Akebono Brake swap
Old May 23, 2021 | 04:00 PM
G3727's Avatar
G3727
Akebono Brake swap
I’m swapping akebono calipers onto my g37x, just wondering what else is different on the Akebonos because I just found a akebono master cylinder and a couple different brackets on z1’s website any info helps, thanks
Old May 24, 2021 | 01:07 AM
spoolin03's Avatar
spoolin03
Rotors lol
Old May 24, 2021 | 08:59 AM
projectpanda13's Avatar
projectpanda13
The brake banjo bolt are different between the base/journey sliding brakes and the Akebono. Cold also just upgrade to stainless steel braided lines.
Are you buying the full kit from Z1? If so, its pretty much complete.
https://www.z1motorsports.com/z1-pro...caAlNKEALw_wcB
Old May 24, 2021 | 09:26 AM
G3727's Avatar
G3727
I got calipers, pads, rotors, z1 braided lines, and I don’t know if I need it but I ordered the sport master cylinder probably wasn’t necessary but if it’s better than the base model master cylinder then whatever. I just got a little worried when I saw hardlines and brackets and the master cylinder labeled for the sport Akebono brakes
Old May 24, 2021 | 09:48 AM
projectpanda13
Normally, it is best to do the master cylinder also because most of the time, cars with larger calipers have a larger master cylinder. it seems that the 1 piston cars use a 15/16" size and the Akebono cars use a 1" size. This will help with the pedal feel. But a lot of people don't swap the master cylinder and are fine with it.
Old May 24, 2021 | 10:19 AM
G3727's Avatar
G3727
I also got the sport brake dust shields. Now are the fitting going to the master cylinder for the lines and stuff all the same?
Old May 24, 2021 | 10:44 AM
projectpanda13
All the hardlines connecting to the master cylinder ar the same.
Old May 24, 2021 | 11:20 AM
RMB5190's Avatar
RMB5190
Got aftermarket or OEM 18'' wheels? If you're still running the stock 17s they won't clear. Everything else has been mentioned for the swap to be successful.
Old May 24, 2021 | 12:11 PM
G3727's Avatar
G3727
I have the base 18” rims
m3clubracer
Feb 17, 2021 11:15 AM
ajcool2
May 30, 2019 12:39 PM
Snappingturtle
Apr 26, 2016 06:45 PM
CRV_33
Mar 15, 2016 04:42 PM
RA080624
Mar 4, 2013 12:31 PM
