2008 g37 coupe oil leak
Old Apr 7, 2021 | 05:51 PM
Jasonkush100's Avatar
Jasonkush100
Hey guys ive been noticing this leak right by my coolant hose, seems like that timing cover was leaking so i cleaned the area and checked for a leak timing cover no leaks, then i thought maby the valve cover gasket is bad checked the valve cover no leaks. My guess is that the valve cover gasket is leaking but only on the side that behind the timing cover. If u guy's have any ideas or thoughts don't hesitate to respond.
Old May 16, 2024 | 12:25 PM
John3.7's Avatar
John3.7
Did you ever find the problem? I have the same issue I’m not sure if it’s the timing cover or the VTC cover. I did the valve cover gaskets so I know it’s not that. I have the same leak around the coolant hose and even dripped down to the ac compressor. But I still haven’t been able to pin point where the leak is coming from. Please let me know if you have fixed this problem
GodlikeRage
Dec 22, 2019 02:19 PM
G333
Mar 9, 2018 01:29 PM
Chris05
14
Mar 29, 2017 11:21 AM
ThebigJ
Jan 27, 2017 07:48 PM
HTNut
Apr 20, 2016 03:06 AM
