After Oil Change/Oil Cooler O-Ring Replacement, Serpentine Belt came loose.
Old Mar 7, 2020 | 07:25 AM
andenimar's Avatar
andenimar
I'll be brief. Yesterday I took my G37 coupe for an Oil Change and Oil Cooler O-Ring Replacement at the dealership and on my way back about 30 minutes later, I heard a sound in the front end area of the car and I completely lost power steering and AC started blowing hot air. The brake and battery light came up and I was able to drive to car to a safe place. Opened the hood and it appeared the serpentine belt came unloose.
Quick question, does the Oil Change and Oil Cooler O-Ring Replacement could have played a part with the serpentine belt coming loose? Do techs have to unbolt or mess with anything near to the serpentine belt parts?
Thanks
Old Mar 7, 2020 | 03:02 PM
Antwone's Avatar
Antwone
I do oil changes on my coupe without touching the belt. Easy as removing the plastic cover under the car, removing oil and filter, and re-adding everything. They probably did a quick inspection at other areas hence the loose belt.
Old Mar 8, 2020 | 07:28 PM
BxG3?'s Avatar
BxG3?
@Antwone Seconded! Shouldnt be any other reason besides that unless there was something underlying that you or may not have noticed/fiddled around with?
Old Mar 8, 2020 | 07:59 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Read the post in full, folks...
Originally Posted by andenimar
I'll be brief. Yesterday I took my G37 coupe for an Oil Change and Oil Cooler O-Ring Replacement at the dealership...
A standard oil change should have nothing to do with the belt. HOWEVER, as OP stated that he had work done to the oil cooler, there is the possibility the tech working on the car monkeyed something up with the belt (unknowingly or accidentally) while he was in there.
I do not believe in coincidences. I would address this issue with the service manager at the dealership and have them make things right.
Old Mar 12, 2020 | 06:26 PM
BxG3?'s Avatar
BxG3?
@ILM-NC G37S You are right, totally didn't see that, tired eyes i guess Also, any updates on what went wrong?
Old Mar 12, 2020 | 06:53 PM
ILM-NC G37S
¯\_(ツ)_/¯
OP has not logged on since he started this thread so who knows...
justinc7100
General Tech Questions
12
Jan 30, 2018 11:17 AM
SmoothJamaican
Jul 27, 2017 01:24 PM
JfromTheBay
12
Sep 8, 2010 11:20 PM
bucknasty
May 5, 2009 11:16 AM
ghideon
26
Aug 3, 2008 04:42 PM
