Car messing up (HELP)
Old Oct 22, 2018 | 01:30 PM
Tbazen's Avatar
Tbazen
I recently bought a 2009 g37s coupe with 97,000 miles. I’ve drove it for snout a week or so with no problems, yesterday I was taking a left turn and the car powered almost co platelet down, had very little power and all lights in car went off. I let it sit for about 5 minutes and turned it back on. Check engine light was on. I took it home and let it sit over night. I woke up this morning and drove it to school, about 10 minutes into my drive I took a left turn and it did the same thing again but only for about 4 seconds and all lights and power came back. Vdc, slip, brake, abs, and check engine light came back on. If anyone knows what is going on any help or tips would be muchely appreciated. Thank you.
Old Oct 22, 2018 | 02:00 PM
youdunseeme's Avatar
youdunseeme
Sorry to hear that bro
Can you get a OBD2 scanner? Or go to autozone ..etc they would do it for free
Old Oct 23, 2018 | 06:19 PM
slartibartfast's Avatar
slartibartfast
Also, be sure the battery isn't moving around and grounding out.
Old Oct 23, 2018 | 08:15 PM
Lunchtime's Avatar
Lunchtime
Low brake Fluid?
Old Oct 24, 2018 | 01:42 AM
crookncastle's Avatar
crookncastle
car may have some simpleton error such as loose connection or perhaps worse case scenario sounds like you got a vehicle that may have been salvaged. either a main ground strap is losing contact or perhaps the battery cables are loose. i would look around the engine compartment and check the engine harness and ground connections along with the battery and alternator connections. btw low brake fluid is not going to set off your ck engine light so don't even bother.
Old Oct 30, 2018 | 12:55 AM
Tbazen's Avatar
Tbazen
Thank you guys for your imput. It ended up being the lonkable fuse connectected to the positive side on my batter, 30$ part 29 minutes of work and it runs like a dream now.
zir
Picture Share G Coupe
Sep 27, 2011 10:40 PM
G3709876
Feb 11, 2011 03:24 AM
G37Sam
Video Share
25
Dec 22, 2010 01:29 PM
Dimitry6
16
Mar 3, 2009 08:48 PM
oOmikeyboy
Photoshop
Aug 15, 2008 02:57 PM
