How fast will battery die out with this ignition on
Old 01-11-2018, 01:46 PM
Ericviera
Ericviera's Avatar
I turned my car off and left ignition on for just a little bit listening to the radio and when I went to turn the car on it died is it normal for the dye out that quick I'm talking about maybe 10 minutes.
Old 01-11-2018, 02:01 PM
NealP
NealP's Avatar
Answer is it varies. What kind of battery? Is it fully charged? How old is it? Is there a bad cell? Were the lights on? No way to know for sure but you can get your battery tested to make sure it's good.
Old 01-12-2018, 12:08 AM
Epiphany
Epiphany's Avatar
No it will not kill a healthy battery in 10 minutes. Was ignition in on or ACC? Only thing I could see is if you had it in the on position and had the seat heaters going too. Your battery is likely on its way out though.
Old 01-12-2018, 01:35 AM
Born2lse
Born2lse's Avatar
headlights are a huge battery drain as well.
Old 01-30-2018, 12:54 PM
Surfnazi
Surfnazi's Avatar
If car is running battery gets charged by alternator
Old 02-01-2018, 03:07 PM
Kris9884
Kris9884's Avatar
I sat for almost 45 minutes listening to an audiobook over lunch one day and it started right up afterwards. Just a normal off the shelf battery from Autozone, nothing special.
limequat
General Tech Questions
10-14-2016 04:57 PM
Newad
08-02-2014 02:35 PM
Quick Reply: How fast will battery die out with this ignition on
