windshield tint @ 55% cant see at night
2008 coupe sport.... dont want to strip the tint because i hate the sun. dark backroads, i have no choice but to run the lights on high. ive notice the light beam is wide but low. i bought this car 2 months ago with only 9200 miles. completely stock. im looking to upgrade the headlight bulbs to compensate for poor visibility. any suggestions? not looking to spend $500 on headlight bulbs... something budget friendly. looking for as bright as i can go without blinding owls in flight.
I've got a suggestion. Strip the tint. The safety of others, specifically bicyclists and pedestrians, is MORE important than your car looking cool. You're a special kind of selfish if you're willing to blind other drivers so you can see.
r2dmax (01-12-2018)
Obviously, you didn't fully read the post. "Driving on dark back roads". Don't know of too many cyclist and pedestrians on back roads driving through the mountains. Geez...
For the most part I have no issues with visibility driving at night it's when I'm driving down very dark back roads were there's absolutely zero light other than the moon and stars above you. I'm not familiar with retrofit projectors. I've never done any kind of modifications for headlights other than cleaning the lenses. Will you please explain? Thank you
The Steering Wheel Guy
It doesn't take "many" cyclists or pedestrians. 1 is all it takes. Or blinding an oncoming car coming around a curve with your brights that can't see you and ends up hitting you. I'd recommend taking the tint off also, which solves your visibility issue and also the issue that it's illegal and dangerous. If something did happen, even a fender bender, you are liable to be considered at fault due to that alone. Keep a nice pair of sunglasses in the car for the sunny days.
You have tint covering your entire front windshield? I've never heard of that. I don't know about where you're located but in most, if not all, states you can't have tint more than 5-6 inches below the top or past the AS-1 line on either side of the windshield or you can get a ticket. I would say if you don't want to remove it all then remove at least everything below that line so you're not putting others at risk and you're within the law.
Check out the laws in your state: https://www.windowtint.com/pages/state-window-tint-laws
Keep the tint and upgrade the bulbs and fogs. In my other vehicles I put in HID projectors with clear lenses for darker shields. For the G models I would get Osram Nightbreakers or CBH or CBI with Morimoto XB led fog housings. I have the CBI and XB with no issues of seeing at night. I think the nightbreakers are the brightest bulb of the three options but the fogs are more 5500k so to color match them you will need CBH or CBI. If all that doesn't help you can get clear lenses and tuning kit. Call up the retrofit source for help on the right lenses. Hope that helps explain the lighting options.
You have tint covering your entire front windshield? I've never heard of that. I don't know about where you're located but in most, if not all, states you can't have tint more than 5-6 inches below the top or past the AS-1 line on either side of the windshield or you can get a ticket. Not to mention that 55% itself is illegal. I would say if you don't want to remove it all then remove at least everything below that line so you're not putting others at risk and you're within the law.
Not sure what state the OP lives in but in VA it is LEGAL to have the entire windshield tinted but you must obtain a medical permit and file it with the DMV.
There are legal 99% UV tints that are almost clear. The light transmissivity will remain above the legal limit, you'll have no issues with vision, and you will be protected from UV light. Knowing this, is your argument really about skin safety or how your car looks?
Well now you're getting into medical stuff. I'm not referring to having tint for medicinal purposes as OP never mentioned it. Most states relax their tint laws if you have a medical reason for it but it doesn't sound like that's the case here.
Maybe you should reread This Thread I clearly stated issues with melanoma in my family including me.
