Rear License Plate Issue.
Hey guys.
On my G, I was trying to replace my license plate cover, then I realized there was only one screw in it. This is because that special plastic piece that's put inside the metal housing for the license plate in the back bumper is missing. If I'm being confusing, it's the white plastic piece that makes it easy to screw a bolt in.
Could someone direct me where to get one? I've tried looking for a little bit but I couldn't find anything. Thanks!
i know the piece you're talking about. mine stripped this past summer so i just put in a stainless steel bolt and nut (it was a pain in the butt to hold the nut from spinning on the inside as you put the screw in, but a nut with an integrated washer and a small piece of duct tape to hold it in place did the trick).
if you're set on replacing the piece, i'd imagine the dealership has them. most, if not all, of the nissan/ infiniti vehicles probably use the same piece. can't imagine why it would be vehicle specific.
