please help with flickering hid....
Old Mar 15, 2017 | 05:30 PM
soundkillr's Avatar
soundkillr
I have been fooling with this headlight on my 08 g37s for the last few hours. I was getting a flickering bulb on start up that fails to light, so assumed a ballast. Been through two ballast now and both ballast do the same thing. Bulb barely flickers and won't light.
it wasn't until my last step I looked at the bulb, the center area right at the bulb is dark brown. Now conventional wisdom would tell me this is in fact a bulb issue, but has anyone ever heard of a failed hid bulb trying to light.
I know this is symptom of a ballast, but having replaced it twice, I doubt it's a ballast. Are there any other areas in the light system that can fail?
Old Mar 15, 2017 | 07:36 PM
soundkillr's Avatar
soundkillr
Turns out it was the bulb, so yes, a bad bulb can flicker just like a bad ballast. Replaced the bulb and everything works again.....
Old Mar 17, 2017 | 06:25 PM
Kris9884's Avatar
Kris9884
In the future, just swap the bulb or ballast in question with the opposite side and the outcome will tell you what the problem is.
