Hill parking with e-brake
Old Mar 7, 2017 | 10:14 PM
Fantality4's Avatar
Fantality4
Hey guys,
I'm a new owner and was wondering if hill parking with an e-brake should hold my car stationary.
Currently, my car rolls down the hill even with an e-brake on. I have to leave my car in 1st gear with e-brake in my drive way because e-brake in neutral doesn't hold my car in place.
Is this normal? I thought the 1st gear was for emergencies in which my e-brake failed?
Old Mar 7, 2017 | 10:17 PM
Epiphany's Avatar
Epiphany
Definitely not normal. Probably needs adjusting. Does having your parking brake on give any resistance?
Old Mar 7, 2017 | 10:59 PM
micafd3s's Avatar
micafd3s
not normal although I would never leave it to ebrake to hold a car in place when parking on a hill..
adjust the ebrake and always throw it in gear when parking.. also turn your wheels towards the curb..
Old Mar 7, 2017 | 11:15 PM
Fantality4's Avatar
Fantality4
Yes the e-brake does give resistance. Without e-brake, my car would roll down the hill much faster.
yeah, i always leave it in gear + e-brake.
1st gear + e-brake on ascending hills, reverse + e-brake on descending hills.
Okay, so this is not normal. My car should hold it's own with only e-brake on and the gears would come in as backups. So, I should go get this checked out?
Old Mar 7, 2017 | 11:18 PM
Fantality4's Avatar
Fantality4
How do you get rid of that "Do you know your computer history" spam...?
Old Mar 8, 2017 | 12:05 AM
Epiphany's Avatar
Epiphany
Do some looking around and there's probably a DIY on here for how to adjust the cable, if not should be fairly easy for a shop to fix up. Under warranty?
Old Mar 8, 2017 | 11:16 AM
sLADe781's Avatar
sLADe781
If you leave your car in gear and someone bumps into it, wouldn't that shatter your tranny? I've seen idiots who can't parallel park back into a car and "push" it back so they can fit into the space and it's always made me cringe.
Old Mar 8, 2017 | 01:09 PM
Maelstrom's Avatar
Maelstrom
I don't think it's a full mechanical cable like older cars. I adjusted mine when I did new rotors. It involves sticking a flathead screwdriver through the little opening in the rear rotors and rotating the "clip" that's in there... That's probably a terrible explanation without pictures, but if you look up DIYs for changing rotors, you should find this step in there and it should make sense.
Old Mar 8, 2017 | 03:26 PM
Glenn2008's Avatar
Glenn2008
Like someone already said, if you are parked down a hill, turn your wheels into the curb. If your parked up a hill, turn your wheels away from the curb.
Old Mar 9, 2017 | 01:10 AM
ctng37's Avatar
ctng37
I had the same problem with my e-brake also. I used this thread to adjust it:
(Post #7)
https://www.myg37.com/forums/general...-question.html
It definitely helped but I'm still paranoid so I just park my car in gear where ever I go with the e-brake.
