C/f duckbill
Old Jan 30, 2017 | 10:42 AM
  #46
steven92's Avatar
steven92
my spoiler comes today........ill make a DYI thread for the install
Old Jan 30, 2017 | 10:27 PM
  #47
steven92's Avatar
steven92
Installed mine today....Some notes:
1. Fitment is 97%, some gaps about 1.5mm in areas. The camera does not sit flush unless you modify the hole in the spoiler like the OP
2. The tape it comes provided with SUCKS. I went to Target and picked up some permanent double sided mounting tape about 1" wide. That spoiler is not going to budge
3. Overall, it looks great. I give it a 9/10
Old Jan 30, 2017 | 10:55 PM
  #48
sharkey's Avatar
sharkey
Wasted no time huh, lol
Old Jan 30, 2017 | 11:13 PM
  #49
WillCo1's Avatar
WillCo1
Very nice.
What exactly did you have to do to modify the camera hole? Enlarge it?
The spoiler has no mounting point for the camera?
Old Jan 31, 2017 | 08:15 AM
  #50
sharkey's Avatar
sharkey
Enlarge all 4 sides is want I did. The camera has a rounded corners, I did enough where it just sort of fell in place. I used a fine file and test fit after every so much was taken out.
There is no mounting point. I made a bracket out of a aluminum strip and short screws
Old Jan 31, 2017 | 08:19 AM
  #51
steven92's Avatar
steven92
Here is a picture of the camera mounted inside the stock chrome finisher. As you can see, it's mounted in place with bracket and screws. The carbon fiber spoiler does not have a place to screw the camera in. I used Gorilla glue and Tape. I don't have a dremel so I was unable to enlarge the provided camera hole. The camera isn't flush, but it's mounted inside the spoiler at the correct alignment.
I made a DIY article:
https://www.myg37.com/forums/d-i-y-i...ml#post4106844
Old Jan 31, 2017 | 10:36 AM
  #52
SiKHG37's Avatar
SiKHG37
Looks good to me!! Thanks for write up also
Old Jan 31, 2017 | 11:25 AM
  #53
The Pope's Avatar
The Pope
Did you (steven92) by chance take any photos of the underside of the CF Spoiler? Just asking because it would be nice to know if there was enough "meat" or whatever on the underside where as studs could be added so that it could also be bolted down like the OEM spoiler.
Old Jan 31, 2017 | 11:48 AM
  #54
steven92's Avatar
steven92
No, but there is about a 0.5" gap. You would have to drill from the underside of the spoiler, and it would be a PITA to match up the holes. I guess you can create a template etc. I used this stuff....it's not going anywhere.
Old Jan 31, 2017 | 12:39 PM
  #55
WillCo1's Avatar
WillCo1
They (Home Depot, Lowes etc) have double sided mounting tape that is a lot more heavy duty.
Rated at 30 pounds, and for outdoor use.
Not saying what you used isn't going to hold, but if it doesn't, this is the stuff to use:
C/f duckbill-nqirxbw.jpg
Old Jan 31, 2017 | 12:42 PM
  #56
sharkey's Avatar
sharkey
Yeah I used the red tape, the white is more general use
Old Jan 31, 2017 | 02:07 PM
  #57
The Pope's Avatar
The Pope
Thanks steve92.
Can anyone else that gets one of these, please post a photo of the underside of it.
Old Jan 31, 2017 | 02:11 PM
  #58
Jonesmeister11's Avatar
Jonesmeister11
Originally Posted by xnick101
http://www.ebay.com/itm/Carbon-Fiber-Rear-Trunk-Spoiler-Wing-Lip-Fit-for-Infiniti-G-Series-G37-2D-09-13/171884452563?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D273c435e017b4c2fa8e63f8158ebf62f%26pid%3D100338%26rk%3D4%26rkt%3D30%26sd%3D302166802916
are you talking about this one?
Wtf shipping is $75?????
Old Jan 31, 2017 | 02:17 PM
  #59
The Pope's Avatar
The Pope
Yes, basically. There are other sellers on Ebay with this same spoiler for less to your door.
Old Jan 31, 2017 | 02:24 PM
  #60
steven92's Avatar
steven92
Yeah, I ordered mine from California, and received it in 2 days with free shipping. I advise not to order from Asia as they are knockoffs
