Can this be done on a G37 coupe
Old Dec 30, 2016 | 06:47 PM
Streetking310's Avatar
Streetking310
Before I get rid of this car I want to go out with a bang meaning make big power I have my lower power N/A build and around summer will order a TT Kit. But I've always wondered can you fun a "big tire" on the back of a G37 Coupe.
I see our relatives (350/370Z) even seen a G35 running a "BIG TIRE" running a 15/16" setup all the time but never on a G37 Coupe
Old Dec 30, 2016 | 10:34 PM
You could run a small diameter wheel if you had enough spacing to bring it out enough to clear the bigger Akebono caliper then run that big sidewall steamroller. You could also run some pretty wide tires on the coupes w/ wheels that would clear the Akebonos if you don't need that Top Fuel sidewall. You could run a 18x11 w/ 315/35/18s, here's the tires
Toyo Proxes TQ
Probably need offset about +50 though.
Old Dec 31, 2016 | 01:39 AM
Presto's Avatar
Presto
The 370z guys do this. I believe the rear brake must be downgraded to a smaller non sport one from the 350z. Lok up info on the370z forums
Old Dec 31, 2016 | 08:29 AM
Streetking310
SO I will most likely need a non sport G rear brakes 🤔🤔🤔
Old Dec 31, 2016 | 08:33 AM
I'll trade you
Old Dec 31, 2016 | 10:01 AM
Rolling your fedners, putting your suspension on air or surely a wide body kit cant make this happen. Unfortunately the g37 body cant run aggressive rear tires or even offsets without dishing out the money to do so. The 350/370 and 35 and have a completely different rear end (wider fenders) than the 37 does.
Old Dec 31, 2016 | 11:17 AM
steven92's Avatar
steven92
Old Dec 31, 2016 | 11:49 AM
^^ that's a g35 lol but a beast in deed!
Old Dec 31, 2016 | 12:44 PM
astat4's Avatar
astat4
Old Dec 31, 2016 | 12:58 PM
Streetking310
Originally Posted by astat4
Them 03-04 Cobra rims that's what I wanted to see but aren't those 17"
Old Dec 31, 2016 | 01:31 PM
astat4's Avatar
astat4
18s. 315/40/18 Nitto nt05r drag radials.
selling em to put 350z base rear brakes to put 15" slicks
Old Dec 31, 2016 | 02:49 PM
Streetking310
Can I get a side angle need to see how far they poke out from fender
Old Dec 31, 2016 | 04:54 PM
astat4's Avatar
astat4
I had to use stock springs to clear the tires
Old Jan 2, 2017 | 03:25 PM
Kris9884's Avatar
Kris9884
Haha I get it, very functional but damn that looks dumb! Do what ya gotta do though. How close are the barrels to the caliper?
