Help - G37X Wheels
Old 08-24-2016, 05:33 AM
meebu
meebu's Avatar
Help - G37X Wheels
I have a 2010 G37X Coupe and Im looking to replace my wheels. If i go with the wider wheels in the back, will it mess up my AWD system?
Old 08-24-2016, 07:58 AM
Abramite
Abramite's Avatar
You can run staggered wheels, but use a tire calculator to make sure the overall diameters of the front and back are within 1% of each other.
Old 08-24-2016, 08:52 AM
Received 4,941 Likes on 4,174 Posts
Pick a set of tires from the following combos, then find wheels that will work with them
18s
235/45 & 265/40 (0.07%)
245/45 & 275/40 -0.07%
255/45 & 285/40 -0.22%
19s
235/40 & 265/35 -0.37%
235/40 & 275/35 0.67%
245/40 & 275/35 -0.52%
245/40 & 28535 0.51%
20s
235/35 & 275/30 0.07%
245/35 & 285/30 -0.07%
This calculator should be used when trying new setups~
Keep in mind the variances with a minus sign have smaller rear diameters, this isn't as good since the rears wear faster, this will cause the variance to increase over time. Not a big deal when you're starting at zero or close, but if you're already almost at 1% variance this needs to be considered. None of the above combos should have enough rear wear to be a issue but
Epiphany (08-30-2016)
Old 08-24-2016, 08:57 AM
VenomGT9
VenomGT9's Avatar
Depending on how much wider you're going, you can run a square set of tires to keep your mind at ease...won't be able to do a full tire rotation but if you stagger you wouldn't be doing that anyway.
Old 08-24-2016, 08:59 AM
G37xhibeet
G37xhibeet's Avatar
Staggered setups ok for AWD
19"
235/40R19 & 275/35R19
245/40R19 & 275/35R19
245/40R19 & 285/35R19
20"
235/35R20 & 275/30R20*
245/35R20 & 275/30R20
245/35R20 & 285/30R20
* - the best of those 6. Puts the rears at 0.07% larger circumference than the front
Old 08-24-2016, 09:00 AM
G37xhibeet
G37xhibeet's Avatar
haha didn't hit post quick enough
Old 08-24-2016, 09:55 AM
Kris9884
Kris9884's Avatar
Man, I wish I had this type of web support and knowledge when I first got into cars 15-20 years ago.
Old 08-27-2016, 12:44 AM
MattCica
MattCica's Avatar
This information is literally what I have been trying to figure out on my own for months lol. Great thread, even better replies!!
Old 08-27-2016, 10:52 AM
slartibartfast
slartibartfast's Avatar
I can email an Excel worksheet to do this to anyone who wants it.
G37xhibeet (09-18-2016)
Old 08-30-2016, 11:36 AM
mizfitg37s
mizfitg37s's Avatar
Slartibartfast - That would be awesome - I'm looking for to buy a new set of wheels/tires for my 2013 g37x S here soon and would love the excel sheet you have. Please forward it to sbsidi@gmail.com when you have some time! Thanks!
Old 09-08-2016, 10:40 PM
13G37
MurderedOutG
13G37's Avatar
I would like one as well please, since I am also trying to get new rims for my 13 G37x.
Email it at itsjrbruh@gmail.com. Thanks
Old 09-18-2016, 06:35 PM
Jeff Schulte
Jeff Schulte's Avatar
what width of wheel/rim to run all four 275? 9"?
Old 09-18-2016, 07:24 PM
9.5" width is a better mount for a 275.
Chris Daher
02-26-2017 05:34 PM
bmsims63
05-01-2016 12:04 AM
VQpoppa
04-09-2016 12:55 PM
nK-
03-28-2016 11:26 PM
Quick Reply: Help - G37X Wheels
