Full Catback Motordyne E370... DRONE! Advice...
ViperG37s (06-18-2016)
LOL ... I was searching and leaning towards the motordyne art pipes. In their website it says that it may eliminate drone. So, with your exhaust set up the DRONE is gone? Thanks.
Didn't get what he said ... anyways, Thank you for the suggestion but is the motordyne art pipes same as the resonators? I looked at the motordyne website and it says that it can decrease or eliminate the rasp and the drone. I wonder if anyone here has the setup with motordyne art pipes and full catback can share
I have ART pipes and full Motordyne catback. Honestly after a few weeks I got used to it. It tends to drone more for me if I shift earlier and its around 2k rpm. If you keep in the sweet spot a little above 3k rpm the drone is minimal, at least for me. I also have 7AT, but this only works if you drive in manual mode which I do almost always.
ViperG37s (06-19-2016)
Found a good deal locally Motordyne Art pipes for my Motordyne full catback set up. Should I get them to hopefully help the drone? Or is it worth it to swap my Berks HFC with the Motordyne Art Pipes? Will my car pass smog in Cali once I swap to Motordyne Art pipes? Thanks.
- They absolutely will not pass smog.
- With your catback, they will still drone (but the Hemholtz resonators help eliminate some rasp).
Maybe someone who has owned both can compare the exact difference in level of drone of berk hfc vs ART pipes.
ViperG37s (06-22-2016)
Ha passing smog with test pipes, ur a funny dude.. It sounds like you absolutely do NOT want rasp, which is good, it sounds terrible. With you needing to pass smog, you should get high flow cats man, they should completely eliminate the rasp all together and still pass smog.
#29
ART pipes are test pipes so that means two things:
#30
